7.3 cylinder numbers? - Ford Truck Enthusiasts Forums
Old 01-13-2008, 11:40 AM
2manykids's Avatar
2manykids 2manykids is offline
2manykids is starting off with a positive reputation.
Does anyone know the cylinder numbers on the 7.3 diesel? My buddy has a 2000 f-250 and on the diagnostic it said 2 and 4 injectors were bad we changed out number 2 and there was no difference and we want to check and see if we changed the right one. My other question is if one injecter is bad will it run like it only has 4 cylinders running? I know nothing about diesels and am learning as I go. My thought proccess is that maybe because we have one bad injector that entire side is not working properly.
Old 01-13-2008, 12:25 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
1,3,5,7 passenger side. 2,4,6,8 drivers side. from front to back
P0269 Cylinder 4/P0284 Cylinder 8 running a little rough mrm8174 1999 - 2003 7.3L Power Stroke Diesel 9 03-07-2016 04:12 PM
5.4 Unusual misfire jpennell1 2004 - 2008 F150 6 06-26-2015 11:29 PM
AE experts mjtpolice76 1999 - 2003 7.3L Power Stroke Diesel 2 05-23-2014 09:27 AM
Cracked head or injector sleeve new2diesel 1999 - 2003 7.3L Power Stroke Diesel 15 01-07-2010 04:37 PM
Injectors pngrantham 1999 - 2003 7.3L Power Stroke Diesel 7 02-18-2007 12:29 PM
Tags
1999, 73, arrangement, cylinder, cylinders, diesel, ford, layout, number, numbered, numbering, numbers, order, placement, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
