Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-13-2008, 10:36 AM
jerg_064's Avatar
jerg_064 is starting off with a positive reputation.
more 302 ??
i've read in a few threads about 1.7 rockers and an electrical fan for more power. Just wondering how much of a HP and Torque increase would i actually feel outta these upgrades. and if i'm better off with something else for approximately the same price.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-25-2008, 05:21 AM
92302FREAK is starting off with a positive reputation.
Iam not 100% sure but I dont think that roller rockers will give you any more horse power, they just free up alot extruded energy by removing the valve springs .
  #3 (permalink)
Old 02-25-2008, 08:42 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
1.7 rockers actually open the valves more than the stock 1.6 ratio rockers, so you will gain TQ and HP. How much? Hard to say but you will feel it from the driver's seat so it's significant. The electric fan is harder to quantify, you remove the constant load of the belt driven fan and substitute an occasional load. In colder weather this will allow the motor to warmup faster which should help milage, but any HP gains will be obtained at higher rpms, so you won't really feel anything from the drivers seat. These are both good mods but for different reasons.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #4 (permalink)
Old 03-15-2008, 07:35 AM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
If you do decide to get some rockers, go all out and go full roller if you can afford it. If you can't, at least get the roller fulcrum. Most people get the roller tipped rockers, but most of the resistance in the rocker comes from the fulcrum.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #5 (permalink)
Old 04-01-2008, 03:09 PM
78F150XLT is starting off with a positive reputation.
what year is this motor? and whats it out of? 94-96 or 95-96 302's in F150s had roller cams already...
__________________
95 F150 Reg. Cab, Long Box, 4X4.
7 inch Lift, 35/12.5/15 Micky Thompson Baja MTZ
4.10 gears w/lockers, AODE w/stage 2 shift kit, B&M shift plus
302 5.0L V8 w/GT 40 intakes, 65mm throttle body, ported H.O. Heads, cam, bored 30-over, Ram Air hood, headers, 3inch exhaust, MSD electronics
Black Projector Headlights/Black Euros
04 Mitsubishi Lancer OZ
  #6 (permalink)
Old 04-07-2008, 07:38 PM
78fordman's Avatar
78fordman is starting off with a positive reputation.
i think the electric fan and the rockers are a good choice. I think you will see more power improvments from the rockers less the fan. Both will only increase top end power. If you are looking for low end maybe a x pipe. are you running a stock cam? If still running the stock cam might want to spend your money on something larger, also something to keep in mind when swapping rockers, that puts more strain on the pushrods and lift assembly, and the engine could float the valves sooner due to the increased lift. I would recomend get a better cam, new double roller timing set, new lifters, a good set of pushrods, your 1.7 rockers, and the matching valve springs.
__________________
2000 F-150 4WD Auto, 5.4, ex Cab
1970 f-100 2wd, 4 speed, 425hp 390
Proud To Be a High Plains Drifter
Tried true 'n blue
  #7 (permalink)
Old 04-08-2008, 12:35 AM
He can't go with too big of a cam because the computer will try compinsate for it and the motor will run like crap... thats if he dont get a custom tune...
__________________
  #8 (permalink)
Old 04-08-2008, 01:30 AM
chrono4's Avatar
Quote:
depends on whether you're on speed density or MAF. MAF will handle it for the most part, but don't even try on speed density.
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #9 (permalink)
Old 04-08-2008, 11:42 PM
i was told that even with MAF it will mess it up... a guy had that problem on his 96 where i buy my parts from...
__________________
  #10 (permalink)
Old 04-08-2008, 11:44 PM
chrono4's Avatar
Not if it's running right. That's why all the hi-po guys want the maf setups off of later 302 mustangs, is because they can mod the engine and it will compensate.
__________________
--Andrew--
Welding a 9"
Technical Advisor
  #11 (permalink)
Old 04-08-2008, 11:53 PM
well i'll see how mine runs cause i put a mild cam by crane cams in my 302 with a gt 40 upper/lower intake w/ ported heads... my truck came from factory with the MAF which was a good thing then for mods...
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
