Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-13-2008, 08:38 AM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
Garage is empty, add now
MikeSDK is starting off with a positive reputation.
Deisel Kleen and B20
I'm sure I've seen this discussed here before, and I've also looked on biodiesel.org, but does anyone else run a little bit of winter DK with their BioD to help with low temp gelling/cloud point/etc.?
From what I've read on biodiesel.org. it seems as though they suggest treat bio just as you would dino D with respect to additives.....does anyone have evidence to the contrary? Thanks
__________________
Mike
2002 F-350 Lariat CC DRW 4x4 7.3L PSD
Isspro EV A-pillar, AIS intake w/ fender sleeve, 5' exhaust, KCM HPX, Tru-Cool Max, BTS VB, RDP FRX, AIH delete, plenum inserts and boots, and Casserly Stage 1 Injectors, 38R and DP Tuner (live tuned) thanks to the gang at RRE 2012!
  #2 (permalink)
Old 01-13-2008, 12:25 PM
07psdrookie 07psdrookie is offline
07psdrookie is starting off with a positive reputation.
I've read to treat Bio differently than Dino. As in, definately run cold weather additive or cut your bio blends a little thinner i.e. go from B100 to B50 etc, in cold weather. I only run B20 about every other tank and use the white/winter bottle of Power Service with no problems so far. Haven't even changed my filters.
  #3 (permalink)
Old 01-13-2008, 03:39 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The Howes diesel treat says it's good for up to B20 on the bottle.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 01-14-2008, 03:24 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans is gaining momentum as a positive member of FTE.slowmans is gaining momentum as a positive member of FTE.
my last bottle of power service (white) says to treat bio- up to b-20 at 1 ounce per gallon of b-20...
  #5 (permalink)
Old 01-19-2008, 08:10 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
2010 Ford F-150
D8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to behold
tim.burke.167
I run B10 with PS white bottle and haven't had any problems yet even with a low temp of @ 10, started rough but ran fine
__________________
~ Tim ~
If you can't stand behind our Military, feel free to stand in front of them!
'10 F150 XLT 4X4 CC shortbed 5.4 *5 Star tuned* No Bailout Edition
07 Road King Classic
GO FLYERS! Go Phillies!
  #6 (permalink)
Old 01-19-2008, 09:25 AM
slowmans's Avatar
I change my above post, the bottle I just picked up says for b-20 to run 3 oz. per gal.? I dont know Im only running b-5 and I only do the 1 oz. per gal and haven't had any problems yet....
  #7 (permalink)
Old 01-19-2008, 09:28 AM
D8chumley's Avatar
Resident smarta$$
2010 Ford F-150
tim.burke.167
I emailed my B10 supplier and he replied they treat their bio w/ antigel good to 0 deg.F and I also do 3 0z/gal PS just to be on the safe side.
EDIT I just went and checked, I do @ 1 oz/gal, I fill up around 1/2 tank usually and add 1/3 of the small bottle( 32 oz bottle) so that would be around 1 oz/gal. but at 1/2 tank it prob. ends up being more than 1 oz/gal actually in the tank I would guess. And no gelling problems yet w/B10
__________________
~ Tim ~
Tags
60, b20, ford, howes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
