Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Large Truck
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Is F-150 Still King?
  #121 (permalink)
Old 03-10-2008, 11:46 AM
Ddot Ddot is offline
Ddot is starting off with a positive reputation.
clark 5 speed
I would be interested in the Clark 5 speed if the numbers are similar to mine, would you mind checking if you haven't sold it already.
Thanks
  #122 (permalink)
Old 03-10-2008, 01:38 PM
Notmeofficer Notmeofficer is offline
1979 Ford F-600
Notmeofficer is starting off with a positive reputation.
Quote:
Originally Posted by rsalter66
I have not been on this thread in a while,
are you still going to shorten the frame and flat bed it?
I can not wait to be able to see it coming together !
this is going to be Sweet!!!!!
Hey is that cab the same size as a regular pick-ups?
could you put a 79 pick-ups bed on it?????
The cab is similar in most repsects.. some of the frame bracketry appears different
I am going to shorten the frame to an 84" cab to axle.. which will fit a 10 foot service body or flatbed.. Im not sure which yet.. theres a bunch to do before I worry about a bed. I could have shortened it to a wheelbase for a lt duty pickup bed but thats not what I want... I need boxes..lots of them.. this is still going to be a fire truck
Next step..
Remove the cab, weld up a buch of holes, media blast it and prime.. put it away for later
shorten the frame.. sounds easy.. its a big job because of the double frame
sandblast, paint, coat...
pull the axles/springs... sandblast and paint,,,new seals... lockers.. hopefully I can get the late model F550 disc brakes to adapt... each rotor is rated for 13k so its definately within specs for the truck even fully loaded
Im going to be busy for awhile
  #123 (permalink)
1979 Ford F-600
Quote:
Thanks
Numbers as follows
Clark 5 speed
MODEL
285V72
06HT
Serial Number
060264 RX
7004NA
You may contact me directly
camismadd@gotsky.com
The 370 is also for sale.. fully complete drop in, right down to the spark plugs.. same 21 k original miles
New fuel pump, new plugs,coil, filters, valve cover gaskets,air cleaner blasted and painted
  #124 (permalink)
Old 03-10-2008, 07:14 PM
rsalter66's Avatar
rsalter66 rsalter66 is offline
rsalter66 is starting off with a positive reputation.
OK, I thought I remembered you saying a while back ago that you were building it to be a Driver ?
what is it that you are going to be doing with it ?
if you don't mind me asking ?
it is still a very cool project no matter what its for ?
__________________
  #125 (permalink)
Old 03-10-2008, 09:14 PM
whd507 whd507 is offline
whd507 is starting off with a positive reputation.
Clark 5 speed
MODEL
285V72
06HT
Serial Number
060264 RX
7004NA
are you sure its 1:1? it was my understanding that the 285V54 is the 1:1 trans, and the 72 was an O/D version.
I think the lower box under the model number should be D6HT (1976-up heavy truck)
my 79 has a 285V54 D7TA 7004 AA box in it, and the bus has a 285V54 D3TA 7004 EA
__________________
1994 Bronco, 1996 Bronco, 1996 E-350, 1979 F-600 Crewcab, 1976 F-150 4x4 4-sp,1976 F-150 Crewcab,1976 F-250CS, 2003 Mercury Marauder and assorted other boring vehicles...
  #126 (permalink)
Old 03-10-2008, 09:47 PM
1979 Ford F-600
This is a vehicle to showcase my fabrication skills, show off some product lines I represent (eagle lights etc), stay in touch with my public safety background (L.A. Sheriff Sergeant (retired), US Coast Guard.. still working boats)... protect my ranch as a fire truck
have a one off cool truck...
Ive built street rods street trucks 4 x 4s to the one ton vintage, including one exploration truck.. but nothing this big....
The fire pump will be a 24 hp hale wildland pump with a 250 gallon poly tank... I also have a Lincoln ranger 10 and a custom made gen set that is going to run a plethera of lights the truck will eventually see..and a zillion interesting tibits I have accumulated over time
I currently run a coast guard disaster comm truck... I have lots of emergency vehicle preparation experience.. and while this truck is going to be mine its going to get the benefit of all my experiences
As to the tranny.. the numbers I posted are taken right off the case.. Ill defer to the experts here as to what it is,,it didnt feel like any overdrive...
Got the cab off today... now onto the frame rails and 200 rivets.. they should be fun to get off... not
cam
  #127 (permalink)
Old 03-10-2008, 09:56 PM
rsalter66's Avatar
I can not wait to see it
__________________
  #128 (permalink)
Old 03-12-2008, 11:31 PM
1979 Ford F-600
Ok.. another day of disassembly...
About 5 dozen rivets fell prey to the air chisel.. enough to wear out two bits and make my arms sore from vibration...
Next step.. cut off about 50 or so welds that hold the double frame together.. the outer frame will be replaced...
slow progress.. this is the dirty stuff
I also got the rear end out.. it will be the next step after the frame... I cant believe how heavy this stuff is...
The 370 and clark 5 speed have sold
Any f 600 gurus have a line on where I might obtain new cab mount rubber?.. mine is very good but I would mind having new stuff... its different than the light duty which are round puck style... the medium duty uses c clamp style.. and pucks
thanks
cam
  #129 (permalink)
Old 04-16-2008, 02:10 PM
1979 Ford F-600
Wow.. how time flies.. gone for awhile,, for some reason the site crashed for me and I havent posted any updates in awhile
Ok .. some progress
Lockers are installed
The front one took 30 minutes because I went very carefully,, the rear about 20 minutes.. easy as pie...
I ordered a set of selectro hubs (got them from Summit and they price matched the lowest price I found in the US).. they just came and are a thing of beauty.. no more spinning front driveshaft
And some pictures of the B700 rotors Im using for my four wheel disc conversion
American economy style.. note taper and thickness of face where wheel abuts
Its thicker than the drum brake face... requiring longer studs
Chinese version import.. note straight barrel casting.. this is good
thickness of face is close to stock drum thickness.. this means stock wheel studs will work
The chinese version wins hands down... funny thing is that it was probably 10 pounds heavier than the American version.. the American casting was finished nicer.. but not by much. The Chinese versions will work with minimal machining of my hubs,, the American version would require alot more work.. neither of the rotors has enough meat to machine them instead,, and then that would also make a custom rotor that would be a PITA to replace
The gears are so heavy that I have to wait for a friend to come over to help me put them back together.. it just needs four hands ..no way around it
I know these pictures aren't hugely exciting.. but its all in the building process and this is the kind of stuff that takes time and patience
Im doing a one off conversion to 4wdb... even different than what the rock crawlers do on the military Rockwells when they disc brake them.. none of that stuff fits my axles or knuckles... but the good news is that there doesn't seem to be any unsurmountable roadblocks. Im going to look at B700 calipers and f 550 calipers next.. the F550s are rated at 13.5 k each.. so they have plenty of oomph... and would match up nicely to a f550 master cylinder and hydroboost
Ive never seen b700 calipers.. so that will take some investigation.. and I imagine the braking system is drum disc with hydrovac.. but again Ill have to look into that
The rotor diameter is 15.2 inches.... the inside clearance of my Stazworks 20 x 12 super single wheel is 17 5/8.. so my caliper height can be about 2 1/2 inches.. I think thats doable (Tires are military michlen xl,, 46 inches tall)... this is going to be one big machine
Im almost done with the domex steel double frame.. probably 20 fitups and at least 80 holes needed to be drilled.. all transfer punched to pickup existing holes in the frame.. maybe another week of part time work... I was able to drill 90 percent of them off the truck on my big drill press.. but some of the top and bottom rail holes will have to be done by hand.. ugh.. a lot of arm strength as domex is TOUGH stuff...
I havent touched the cummins and allison yet.. Ive been too busy...
A buddy also suggested his detroit 6v53 motor which is sitting on a test stand right now.. it might be too much for the truck.. its hotrodded and about 450 hp.. but its free and in excellent shape.. many firetrucks used detroits... its shorter than the cummins but a monster at about 1600 pounds.. of course I do have a medium duty rig.. and I do LOVE the way detroits sound.. they are so distinctive
Slow..progress
  #130 (permalink)
Old 04-16-2008, 02:52 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by Notmeofficer View Post
Any f 600 gurus have a line on where I might obtain new cab mount rubber?.. mine is very good but I would mind having new stuff... its different than the light duty which are round puck style... the medium duty uses c clamp style.. and pucks thanks cam
C7TZ8100165A .. Rear Cab Mount Absorber Kit
MSRP: $132.98 / ftepartsguy.com price: $95.75
Kit consists of absorber, retainer, spacer.
This is the correct kit the heavy truck parts catalog shows for 1973/79 F600's, for the rear cab mounts.
I believe you said someone told you the cab mounts (absorbers) were not available, but that's not correct...at least for the rear.
Check it out yourself, you have the same parts catalog I (now) do = TEXT: Body Section 100 / Page 10 / Body Bolt location #2 Cab Rear. Then type the part number into ftepartsguy's website.
The heavy truck parts catalog (I now have 1973 thru 2002), doesn't say if this kit does one side or both sides.
I could find no part number for the front cab absorbers for 1973/79 F600's that still showed available from Ford, but the type used 1980 and later on F600's is still available from Ford.
Check with ftepartsguy, the part number for the F600 front absorbers for 1973/79's may have been replaced by the 1980 and later type. I have no refs to tell me this, one way or the other.
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #131 (permalink)
Old 04-16-2008, 10:11 PM
1979 Ford F-600
Bill
thanks for your practiced eye.. I have the parts manual... but I certainly like your input instead.
Worst case scenario I was going to go directly to prothane or get a chunk of polyurethane myself and make them
As we both know custom making stuff takes forever.. Ive been on the frame doubler for a month part time and Im just seeing daylight. I calculated that the 80 or so holes I had to drill have taken hours to do (domex is drillable but it is tough and eats titanium coated drill bits like candy.. slow and plenty of cutting fluid is the only way to go)
Again.. thanks
cam
PS... pic of the selectro hub
I forgot to add... the front locker was easy to find,, the rear,, the rear was only NOS available... I found a Detroit distributor that had two left,, that was all there were in the US.. I paid dearly for it,, but oh to have that locker
  #132 (permalink)
Old 04-16-2008, 10:23 PM
1979 Ford F-600
I would love to do a 2wd slammed to the ground with a car carrier body..... post up some pics when you get a chance
  #133 (permalink)
Old 06-27-2008, 10:26 PM
1979 Ford F-600
Well.. a couple of months have gone by and Im still amassing parts.. the 20 " custom wheels and 46 inch military xmls from John at Stazworks have held me up.. but Im in the last month of waiting for them..
The lockers are done and went in without a hitch
The dual frame is done,, unpainted
I have been super busy and havent had the time to devote more than an hour here or there.. perhaps after the fires slow down and I get the thing to rolling chassis and out of the 100 degree sun and back into the shop things will speed up
Pictures will follow at some point.. next tasks
sandblast the frame
build the calper stands when I have the wheels in hand
  #134 (permalink)
Old 07-01-2008, 12:05 AM
FE406 FE406 is offline
FE406 is starting off with a positive reputation.
Officer, I've watched your progress with great envy over the last several months as I also own one of these precious beasts(1969 F600 4x4). Unfortunately I've got to let mine go. Hopefully to an owner who has 1/10 the appreciation and skill you posess. If anyone is interested please check listing #190233453716 on ebay. LOW RESERVE
I apologize for hijacking this thread. I'm sure some members might flame me for not listing it here. Long story short, I had a free listing to use, and didnt know if listing on both sites at the same time might cause conflict. I just thought these trucks are a bit rare and wanted to inform any FTE members of its availability ( I plan on making it up by exlusively listing my '76 highboy on FTE. 60k original mi., unmolested and rust free.).
Keep up the great work. That truck is gonna be sweet when your finished.
Walt
  #135 (permalink)
Old 09-19-2008, 10:04 PM
1979 Ford F-600
The build is proceeding after a summer off.. because of forest fires
The 46" XMLs are being delivered monday afternoon...Stazworks dropped the ball taking 5 months for what should have taken 30 days and I had to get on their butt..hopefully there wont be any disappointments.I dropped 3500.00 on 5 custom wheels and military tires... which is almost what the truck cost originally.. I located some NOS parts such as axle wiper seals etc.. which I would have had to make ... Arvin Merritor.. the people that bought Rockwell .. still have some stuff around.. finding the orginal parts crossover sheet was an act of God.. it took me a month but I have it and from it I found some little things I wanted to make the axles like new...
The frame doubler is all done.. Im working on some sub assemblies.. stubborn spring hangers etc... slow progress... until I get it back to a rolling chassis it seems like all hard work
maybe some pics soon of progess
Cam
Tags
1972 , 330 , 4x4 , 73 , 78 , 79 , cab , crew , emissions , engine , f100 , f600 , ford , hd , sale , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
