The motor ended up being a 370 CI industrial.. which they started using circa 1980.. the build date on this was late 79 and the 370 was actually spec'd on the orginal build order sheet.. which I ended up getting form the original fire company/owner
we had a '79 f-600 with 370 that was ordered early march of '79
__________________ Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
except for the speed limited box under the dash, the distributor, ignition module, coil, wireset, cap/rotor and plugs are the same as any 460 in a pickup. 44/45 is typical. I cant find my book that has them listed, but I'm sure its .044.
New plugs helped a bunch (fire trucks typically get loaded up from pumping)
If it would stop raining for an hour Id take the thing up on the freeway and get it hot and clean it out.. alas.. looks like a week or so of solid wet stuff
Next step...
Weld up some dash holes.. and reshoot the interior in factory silver.. which just happens to match rustoleum aluminum really close.. good enough to pass
I found shifter boots after lots of searching.. the tranny boot was expensive (50) and the transfer case ones ended up being (30) or so.. ouch.. but "very purdy"
Next step...
Here's a suggestion.
You can order a CD version of the 1973/79 Ford HEAVY Truck Parts catalog from hipoparts.com. Also sold on ebay. The cost is around $25.00.
No more searching for part numbers, specs, or illustrations...the parts catalog has it all.
__________________ Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
Well..Im back at it.. I now have the truck down to cab and chassis.. it was a boatload of work but Im there..the truck is definitely peppy now..... this week I will remove the fire pump and shorten the chassis... then the real fun can begin
The cummins will be coming apart for a look see to make sure it is excellent.. new gaskets etc...
Does anyone know if the cab mounts are the same as the lt duty?.. I want to put new polys under the truck while I have it down this far..
things Im looking at
super singles and 52 inch military michelins.. from USA 6 x 6
yes pics.. I know.. the WIFE is going to get some tomorrow
