Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-13-2008, 08:51 AM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is starting off with a positive reputation.
360 gettin 7.5 mpg!!
Just figured out my gas mileage last nite, pullin 7.5 mpg. I know im gonna get the responses "Its a truck with a 360, it wont get good gas mileage" Well; no ****, but I'm just lookin for anything that will help. Its got a cam, long tube headers with a 470 holley truck avenger. Any thing else that could help at all. I'm lookin to do an Edelbrock intake here soon, and possibly a new ignition system. Any suggestions though?
__________________
99 F150 Under the knife again. SAS, 1tons with 17.5 "'s of lift with 44's.
77 F250 For Sale
2001 F250 7.3 lariat 4x4.
  #2 (permalink)
Old 01-13-2008, 10:21 AM
73F100*8Mile 73F100*8Mile is offline
73F100*8Mile is starting off with a positive reputation.
LOLOLOLOLOL----Been there! Ya, pull the motor and make it a 390!! Twice the mileage and feels like twice the power and can be if you want it!!
__________________
1973 F100 390 C6
1990 Honda Accord
1968 Hardtop Mustang I6 200
1977 E-150 351w
1968 Fairlane 302
  #3 (permalink)
Old 01-13-2008, 10:27 AM
tankrsc tankrsc is offline
tankrsc is starting off with a positive reputation.
Quote:
15mpg out of an FE in a truck dang that would be nice. I only got 18 out of my old 77 with a 302.
  #4 (permalink)
Old 01-13-2008, 12:29 PM
TheTinian's Avatar
Think a new intake will help at all? Its got the stock one now and lookin at a Edelbrock.
__________________
77 F250 For Sale
  #5 (permalink)
Old 01-13-2008, 12:36 PM
condolan condolan is offline
condolan is starting off with a positive reputation.
Intake might help a little bit. But I woudn't expect any huge gains. The 360's are already notorious for getting less than 11 mpg, the carb doesn't help much either, although it doesn't necessarily hurt (my 2-barrel gets 8). The ignition system might help too. If you avoid big tires, add in a dual exhaust, and drive with a foot that's lighter than air, the odds are your gas mileage will improve.
But no promises...not with an FE.
__________________
1984 Ford F150 4x4 (300 Six, 4-speed)-daily driver
1974 Ford F100 4x4 (360 V8/C6)-burnt up
1979 Toyota 4x4 pickup-rusting away
If you don't like the weather in Montana, wait 5 minutes and it'll change.
  #6 (permalink)
Old 01-13-2008, 01:34 PM
I'm no expert but I don't see any 360 getting better than 8mpg unless you do some deck shaving. It lacks the efficientcy of quench. And thats only if you really wanted to stick w/ the 360 for whatever reason. At that point, I'd just get the 390 crank/rods to complete a great setup for 30+ cubes more. Also, when bumping up the compression on a 360, you're still running weaker rods than that of the sister 390. So it's almost a no brainer. Build a 390, pass rice burners/chiivy lovers grinning.
__________________
1973 F100 390 C6
1990 Honda Accord
1977 E-150 351w
1968 Fairlane 302
  #7 (permalink)
Old 01-13-2008, 02:02 PM
blue68f100's Avatar
blue68f100 blue68f100 is offline
blue68f100 is starting off with a positive reputation.
My 360 (2V, headers, dual exh, other wise full stock) with 3.25 rear end ratio use to get around 10 mpg when it was tunned properly. 8mpg is a little low unless you have low ratio rearend. Now with all of the work I have done it still only gets around 8mpg. Back in the 70's it use to avg 10-12 with the higher octane fuel, provide I remember to take the manual choke off. Lower the octane the less energy you get from it. So if you can get up to 10mpg that should be about max. As for a 390 getting 15, I would question it. But this summer I may find out if I get all of the body work done. I still don't expect anything more than 12.
__________________
68 F100, mod 360, C6 Auto
  #8 (permalink)
Old 01-13-2008, 06:47 PM
royalchoppers royalchoppers is offline
royalchoppers is starting off with a positive reputation.
"Lower the octane the less energy you get from it."
From what I understand that is a common misconception. There are many articles that point out that the lower the octane the hotter the fuel burns. Higher octane only allows the engine to run high compression without detonation. So if you don't have high compression you should run as low of octane as you can with out pinging. Not trying to start a huge debate but just something I found interesting.
Check out at the bottom of the page at number 3. Just one of the sights that discusses this topic. Sorry to interupt the thread. http://www.rc51.org/fuel.htm
__________________
In 4130 we trust.
www.myspace.com/royalchoppers
  #9 (permalink)
Old 01-13-2008, 07:00 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
Gears, tires, rpm you run it at?? These all mandate the mileage you'll get.
Tune up helps, but got to know how you drive it first.
__________________
*signature delete option*
  #10 (permalink)
Old 01-13-2008, 07:14 PM
Ford428CJ's Avatar
Ford428CJ Ford428CJ is offline
Ford428CJ is starting off with a positive reputation.
Here is what you do to help your mileage.
* First if you have points, change them out with a pertronixs or a mid 70's dizzy! Or a aftermarket one would be best (only if you are going to make engine changes down the road and tune-ability).
* Next a intake for it. I would rather see you run a Blue Thunder or if not, then one of these RPM, F427, PI, and very last (and I do mean last) a performer. You may upgrade your engine later and have a kick a$$ intake in hand when needed....
* Headers! Get a good set of headers like Hooker Comps (NOT the supper comps) and a dual 2 1/2" exhaust straight out the back with muffs on it.
* Run a Box on it (Either MSD or a Mallory) 6 with coil. I have ran both and I like both of them. NO Issues, no matter witch way you go!
* Setting your timing is also a big deal too. Total between 34-36 degrees.
* Big one here is gearing. Running down the highway and taching 2,100-2,300RPMs doing 55-60MPH.
Those are things that need to happen "IF" you want to squeeze the mileage out of it. You should be able to get 14-16mpg. Also I think that 470 is a little small, I would have liked to see a 600 on it. But I guess it doesnt matter if you are looking for mileage only. JMHO is all it is.......
__________________
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
  #11 (permalink)
Old 01-13-2008, 08:28 PM
Dave Severson Dave Severson is offline
Dave Severson is gaining momentum as a positive member of FTE.
Guess I'd be for doing all the things that Wes suggested, just think I'd be doing it to a 390 instead of a 360!!!! Better efficiency with the 390, which would be an improvement in mileage and performance. When the 360's were built, fuel mileage was not an issue. Because of this you can't really compare that poor 360 to the more modern trucks with enitrely different design criteria, numerically lower gears, overdrive transmissions, etc. None of this will improve the fuel mileage of your 360, I guess IMO the best way to improve it would be to replace it. If you consider the cost of all the mods vs. the 3 or 4 mpg improvement in mileage you never would get your money back..... Build a big torque 390 for power, and drive an Escort for fuel mileage, works for me!!!!!!
__________________
Anybody can restore a classic, takes a man to cut one up......
  #12 (permalink)
Old 01-13-2008, 09:41 PM
TheTinian's Avatar
Thumbs up
Ok, well I already have a set of long tube header (dont know what brand though), with straits and dual 40's. Also have 4.10's with 37's. It dont do bad RPM wise i can run between 65-70 at about 2000. I know im not gonna be able to push to much out of it, just 7.5 mpg is kinda harsh at 3.10 a gal. I really dont have the money to upgrade everything to make it a 390 right now. But i guess well see....
__________________
77 F250 For Sale
  #13 (permalink)
Old 01-13-2008, 09:43 PM
TheTinian's Avatar
And yeah i know a 470 is somewhat small, it had a 600 holly on it when i got it but it crapped out on me and i had this one laying around so threw it on there. It really isnt that bad though.
__________________
77 F250 For Sale
  #14 (permalink)
Old 01-13-2008, 09:44 PM
Ford428CJ's Avatar
Quote:
Well If he does all those things that I had mentioned, his mileage will increase. I bet he could pull 12 to 14 easy (not impossible to due with a 360 but I dont know the history of his engine). There are quite a few guys on here and other forums that pull mileage with a 360. No kidding.......
Besides that if he does build a 390 then he has all the good stuff that he is going to need to begin with (Intake, dizzy, headers, exhaust and so on). So if you do what I said (and you can do a part at a time over the weekend) then you wont be down trying to gather parts. Your truck will stay running and then you can find a 390 to build with out any down time. Have a nice long block ready to go!
__________________
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
  #15 (permalink)
Old 01-13-2008, 09:49 PM
TheTinian's Avatar
This 360 has been rebuilt recently. Supposedly (according to the previous owner) it has less than 12,000 miles on it. And it was a total rebuild, not a half ass one that ive known some people to do. As for the intakes you mentioned, where can i find them?
__________________
77 F250 For Sale
Tags
1970 , 360 , 390 , 73 , 75 , choke , f100 , ford , gas , increasing , man , manual , milage , mileage , mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
