Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-12-2008, 09:13 PM
mybigredford mybigredford is offline
mybigredford is starting off with a positive reputation.
up pipe leak
is this an up pipe leak??
__________________
CLINT
2002 F350 XLT 7.3L PSD 4X4 Bellowed up pipes, HPX, CCV mod, foil delete mod
  #2 (permalink)
Old 01-12-2008, 09:35 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of
hard to tell in that picture.it looks like it...but i stole this from KwiKK..you can see soot at the top of the pipe on the left..
__________________
Early 99 7.3 F350 auto,GTP38R BB turbo, AFE stage2, 5" strait pipe, DP live tuned-PMT1 soon to happen, 140 IDM, Terminator Modified 17* HPOP , DIY fuel bowl delete, DI Regulated Return fuel feeding Ryan Casserly's SS stage 2's moded EPD process 100% over nozzles http://fullforcediesel.com/
exploded view of a 7,3 << more pix of my truck
  #3 (permalink)
Old 01-12-2008, 09:41 PM
STROKER350 STROKER350 is offline
STROKER350 is starting off with a positive reputation.
Look's like it's leaking to me. If you are going to fix it, check out Black Widow Diesel for some good looking up pipes to fix it right.
  #4 (permalink)
Old 01-12-2008, 10:03 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
It's fuzzy, but that's soot alright. Definately get rid of the donut gaskets and get the bellowed up-pipes. BWD is where I got mine. At the time they were cheaper than the IH dealer close to my house.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #5 (permalink)
Old 01-13-2008, 12:11 AM
i know my pic is a little fuzzy, but it was the best i could get, and by the looks of the pic rons power stroke posted, thats how mine looks, allthough i couldnt see the pass side up pipe, it looks as though the bolt on the back could be a little difficult to get at, did you guys have to put some penetrating oil on them first?? and what are they supposed to be torqued to after. any other tips before i try this one out, i bought the donut from ford today, not sure of the price of these bellowed pipes you guys talk about, they might not be in the budget.
__________________
CLINT
  #6 (permalink)
Old 01-13-2008, 12:58 AM
Pocket's Avatar
BWD has the bellowed up-pipes for $300: http://shop.blackwidowdiesel.com/pro...&productId=304
Here's how to replace them: http://guzzle.rbmicro.com/upp.html
__________________
Curtis
2002 F-250 PSD
Truck Pics
  #7 (permalink)
Old 01-13-2008, 01:04 PM
Quote:
in this procedure they are putting in bellows, i just want to replace the donut, do i still have to take the turbo off or just unbolt the upipe connection and replace the donut, bolt it back together??
__________________
CLINT
  #8 (permalink)
Old 01-13-2008, 01:21 PM
orcas tow orcas tow is offline
orcas tow is starting off with a positive reputation.
You can get to all 4 top up pipe bolts to check torque from the bottom with a long extension & a 10mm universal socket (maybe 3/8", I dont remember) but your working pretty blind so getting the bolts out would be easy but putting them back in would be a bugger.
I just did this job yesterday but replaced the up pipes with the Black widow bellowed pipes, I was wondering if I wasted my money but after getting the old pipes out (by pulling the turbo to replace the pedestal/turbo o rings at the same time) I was glad I had the bellowed pipes on hand.
My 2001 F550 only has 30,000 miles & where the donuts sit on the pipe they had all but rubbed through, as the exhaust heats up & cools down it moves due to expansion & contraction, after multiple warm up cycles it wears a groove in the sealing surface of the pipe, I could not have sealed mine with gaskets due to this wear & its not a job I would want to do again soon. Thats my $.02
  #9 (permalink)
Old 01-13-2008, 01:45 PM
spinge spinge is offline
spinge is starting off with a positive reputation.
Quote:
Originally Posted by orcas tow
You can get to all 4 top up pipe bolts to check torque from the bottom with a long extension & a 10mm universal socket (maybe 3/8", I dont remember) but your working pretty blind so getting the bolts out would be easy but putting them back in would be a bugger......
.......& its not a job I would want to do again soon. Thats my $.02
AMEN to that. Yes, you can get to them from under the truck, with about 3 miles of extensions, 2 universals, and 2 more elbows in your arm. When I replaced mine on the F450 (before the bellowed pipes were available), it was a bear of a job, and they are leaking again. It has only been about a year. Look in my gallery for a picture of the up pipe with a hole worn in it from the donut, as well as the ear that broke off of the babies butt. These are the parts I took out the last time. When you go to the bellowed kit, all of the parts are new. For reference, try to find a babies butt at 4:00pm on a Sunday afternoon - not happening.
My .02 - (actually .03 after taxes) go with the bellowed kit. It is a more permanent fix to the problem (the 6.0 has the bellowed pipes, and that is one thing that is not a problem on them). It costs more in the first place, but like any repair, it is more effective if done right the first time.
__________________
Rich
'00 F450 Reg Cab Work Truck-7.3, 196K miles, 11' Work Body.
'03 F250 Lariat, CC 4x4-6.0
AE
  #10 (permalink)
Old 01-13-2008, 02:11 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
I second that. Get the bellowed pipes and never have to deal with that problem again.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #11 (permalink)
Old 01-13-2008, 02:16 PM
just another truck's Avatar
just another truck just another truck is online now
of "Smoking"
just another truck is a splendid one to behold just another truck is a splendid one to behold just another truck is a splendid one to behold just another truck is a splendid one to behold just another truck is a splendid one to behold just another truck is a splendid one to behold just another truck is a splendid one to behold
sorry to but in, but didnt someone on this site also recomend heading to the intenational dealer and getting pipes from them, cheaper then then the bellows, but with out the donut?
__________________
Pat
Paa 67
"A woman drove me to drink and I didn't even have the decency to thank her. "
"I don't like to commit myself about heaven and hell - you see, I have friends in both places. "
  #12 (permalink)
Old 01-13-2008, 04:05 PM
well i cant afford bellows right now, but was that hole in your pipe from the donut or from the clamp rubbing? and could you weld and grind it back to shape if needed. should i even bother changing the donut and just leave it as is?
__________________
CLINT
  #13 (permalink)
Old 01-13-2008, 04:36 PM
if its leaking then you have lost boost and fuel mileage..if it leeks it needs to be fixed..I did mine with pipes off of an 01 cause I updated from the early 99 turbo.and could not afford the bellows...the pipe had a hole in it for EGT probe..I welded the hole and ground it back down,, my probe is on the exhaust manifold...itsbeen almost a year now and there still holding up well..
__________________
  #14 (permalink)
Old 01-13-2008, 04:38 PM
I would leave it as is until you can afford the bellowed up pipes, the International up pipes (which are bellowed) are what Black widow sells but even with my shop discount at International Blackwidow was about $10 cheaper
  #15 (permalink)
Old 01-13-2008, 04:58 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
Hey Spinge, I'm working on Greedy's truck (the bellowed pipes, picking them up tomorrow, and WW) late this coming week. LMK if you want to come and hang out.
__________________
2002 F-350 with some mods, current best 12.8 @ 104 Fuel only
Spooled, Fueled, and Tuned by Swamps Diesel Performance, Trans by BTS, Engine built by me
Swamps gives me enough power to break a BTS
Tags
1997 , 73 , 99 , early , f350 , ford , gasket , gaskets , leak , leaking , pipe , pipes , powerstroke , replace , uppipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
