Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 01-13-2008, 05:12 PM
spinge spinge is offline
spinge is starting off with a positive reputation.
Quote:
Originally Posted by mybigredford
.....but was that hole in your pipe from the donut or from the clamp rubbing?
The hole was from both. I am sure it could be welded and ground. I am torn on my recommendation. There is the danger of breaking the ear of the babies butt, or damaging some other part that tells me to leave it the way it is. On the other hand, it is making your truck louder in the cab, poorer performing, and less fuel efficient. With diesel WELL into the $3.00 range, it does not take long to burn out of the tank the cost of the pipes. That alone is reason to do the repair, not to mention the noise and performance.
Kris, I will PM you if I get time in my schedule at the end of the week - I think I may...
__________________
Rich
'00 F450 Reg Cab Work Truck-7.3, 196K miles, 11' Work Body.
'03 F250 Lariat, CC 4x4-6.0
AE
  #17 (permalink)
Old 01-13-2008, 05:27 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
I'll be getting quite good at doing the turbo removal/ up pipe install procedure, ive done it twice already and once more this week.
__________________
2002 F-350 Thats been nothing but a waste of time and alot of money!
  #18 (permalink)
Old 01-13-2008, 07:16 PM
mybigredford mybigredford is offline
mybigredford is starting off with a positive reputation.
thanks for the help guys, i will have to make some decisions about this one of these days, i took a look again today under the hood at it and i cant even see the pass side to see if it is leaking, need to get my mirrior out, that one could be a pain to get at, but i am sure it is leaking it the drivers one is
i cant say about the noise in the cab because i am not sure how long they have been leaking, but once i do change the nuts i will be able to tell. i think i may be down on power from this cause it seems that i dont have much power when it is in third gear and i am going up a slight incline, it always downshifts and doesnt seem to be much spoolin of the turbo until it downshifts, so maybe the leak is enough to do this.
__________________
CLINT
2002 F350 XLT 7.3L PSD 4X4 Bellowed up pipes, HPX, CCV mod, foil delete mod
  #19 (permalink)
Old 01-13-2008, 08:28 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
is this an up pipe leak??
Quoted from your original post, minus the picture.
I can with 100% confidence say that your up-pipes are leaking because of the black streaks just below the flange in the background.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #20 (permalink)
Old 01-13-2008, 08:37 PM
The reason I suggest doing the bellows is because after less then a year, mine are leaking again (Old Style). I didn't realize the amount of noise I was getting until I did them the first time, it was a major difference, but then mine were REALLY bad. I was actually having a trans temp issue, because the engine was down on power, and the computer was modulating the transmission in an attempt to compensate for the lack of power (my tranny was running 200* in the winter). Did the up-pipes and the temp dropped about 40*.
__________________
Rich
AE
  #21 (permalink)
Old 01-13-2008, 09:06 PM
Jesus spoke a lot
1999 Ford F-550
Wow, spinge, that's an interesting twist to the story.
__________________
Dan
God and Dog
  #22 (permalink)
Old 01-13-2008, 09:12 PM
Quote:
Isn't it though - but completely true. The tranny was still under warranty at the time, and I took it to the local dealer, due to it running hot. Dealer said it was not the tranny, but the exaust leaks pre-turbo causing the problem. He wanted a fortune to do the job, but explained what I needed to do at no charge (imagine that!) and he was spot on the money. I would not have believed it except for that I actually did the repair myself, and the NEXT DAY the tranny was running cooler.
Truth is stranger then fiction.
EDIT: And remember - all that heat is wasted energy (fuel)
__________________
Rich
AE
  #23 (permalink)
Old 01-13-2008, 10:06 PM
hey spinge how long did it take you to change the donuts the first time you did it before you got bellows?
__________________
CLINT
  #24 (permalink)
Old 01-13-2008, 10:21 PM
Probably about 6 hours, and I had never done it before. That is actual hands on time. It was about 2 days total to repair, because I broke the ear off of the babies butt (it had been cracked) late in the afternoon on the weekend, and I could not get a new one until Monday. I took the turbo off, and while I had it off I replaced the pedestal o-rings.
As a clarification, I have not put on the bellowed pipes yet. The first time, I bought the kit from powerstrokeshop.com that had the plain up-pipes and all of the hardware. The parts the pi$$ed me off were (1) The bellowed pipes came out shortly after I replaced mine with non-bellowed and (2) with the cost of the kit, plus the babies butt from the dealer, I was only about $80 less then the bellowed version.
__________________
Rich
AE
  #25 (permalink)
Old 01-14-2008, 01:02 AM
so the turbo has to come off just to replace the donuts?
__________________
CLINT
  #26 (permalink)
Old 01-14-2008, 01:08 AM
Pocket's Avatar
Pocket Pocket is offline
Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold Pocket is a splendid one to behold
Yep, unless you can figure out a way to get behind the turbo. But like it was mentioned before, you need another two sets of elbows to make that happen.
Or you can drop the trans to access it.
Or if you have a van......
Either way it's a lot of work for just two donuts. That's why so many folks recommend going with the bellowed pipes and get it over with for good. After taking them apart and looking at the design, it's terribly flawed. Some argue that the donut gaskets for the Chevy's are better since they are bigger, but guaranteed they will eventually leak again.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Truck Pics
Quote:
The phrase "It'll make a turd" is not considered a compliment when referring to the quality of dinner.
  #27 (permalink)
Old 01-14-2008, 07:37 AM
What Pocket said.
__________________
Rich
AE
  #28 (permalink)
Old 01-14-2008, 09:51 AM
well this sucks
thanks again for all your help, maybe i will hold out for some bellows one day, i think you convinced me now
__________________
CLINT
  #29 (permalink)
Old 01-14-2008, 09:58 AM
Jesus spoke a lot
1999 Ford F-550
What Pocket said.
And again. I redid my donut pipes and in less than six months they were turning black again.
__________________
Dan
God and Dog
  #30 (permalink)
Old 01-14-2008, 10:23 PM
Which also sucks
__________________
Rich
AE
Tags
1997 , 73 , 99 , early , f350 , ford , gasket , gaskets , leak , leaking , pipe , pipes , powerstroke , replace , uppipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
