ARP Rod Bolts
ARP Rod Bolts
Is it Possible to put the ARP high performance wave-loc Rod bolts on D6 rods. The reason I ask is because they are only made for the Boss 429-460. Am I just going to have to use the regular ARP rod bolts. For the same price Id like to use the better of the 2 but if it wont work ohwell.
Thanks in Advance
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
[link:www.tarleton.edu/students/jwillms/ChasesOldFord.com|My Truck]
Thanks in Advance
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
on
1 Post
ARP Rod Bolts
You can install ARP wave-loc's on the D6,CJ and 429 Boss "T" rods. These rods use a 3/8 rod bolt. The 429 "S" and the 429 NASCAR rod use a 1/2 tri-lob rod bolt. The D6 and the 429 Boss "T" rod are almost the same with the exception of the weight 'GRAMS' between the two. The T rod was alittle beefier around the beam area. About 30 to 40 gram difference. I had the wave-loc's installed on the D6 rod, make sure you have the big end resized.
77 F250 4X4
77 F250 4X4
ARP Rod Bolts
I guess I should have clarified what rods I have. I am pretty sure they are D6VE rods and not the truck rods. Im pretty sure the ARP rod bolts with the football shape head will work but I'd like to make sure before I try it. So any info would be great. Sorry about the goof with the rod type.
Thanks in advance
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
Thanks in advance
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
ARP Rod Bolts
Well the rod bolts that are on now arnt football shaped, they are rectangular. Now I dont know which bolts to use. Is there a certian way that the wave lock or football shape bolts have to be installed, I know the process for regular rod bolts but if there is a differece I guess I better find out if the shop can do it.
Thanks
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
Thanks
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
on
ARP Rod Bolts
There is no differance in the way they are installed. Your connecting rod will be stronger with the ARP bolt but not quite as strong as the truck rod since the broaching on the truck rod is circular by the bolt head instead of a straight cut as on your rod. Make sure the rod ends (large end) are re-sized after installing the ARP bolts or you'll be rebuilding the engine again after you spin a bearing or seize the crank.
I'd say as a general rule of thumb that with ARP bolts and your car style rods you'd be good for 6000 RPM maximum. With truck rods and ARP bolts I'd limit spinning the engine to 6500 RPM. Of course if your still running stock factory pistons you'll be limited to 5000-5500 RPM no matter what rod you have...Deen
ARP Rod Bolts
I guess wave locks it is then. I appreciate all the help guys, thanks a bunch.
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
