Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-12-2008, 04:25 PM
JCastellaw is starting off with a positive reputation.
Fuel Gauge
My friend has a 74 bronco and the sending unit is not getting any current to the sending unit. I checked the fuse panel and all fuses are hot. Is it the gauge? Any way to check without going behind the dash?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-13-2008, 03:01 AM
fordtrucksforever is starting off with a positive reputation.
Check resistance on the sending unit. It should be between 10 and 90 ohms, give or take... Then check continuity on the wire(s) running to dash.
  #3 (permalink)
Old 01-13-2008, 11:16 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
You're not getting any voltage at the sending unit wires? Do you have a good ground? Ground seems to be the most common problem that I find.
Are any of the other gauges malfunctioning? The fuel, temp and oil psi gauge get reduced voltage power from a voltage regulator (about 5-6 volts, as I recall).
Check for input voltage at the gauge and then check the stud that goes to the sender. If you have voltage in but nothing out, the gauge is bad. Since dual tanks were an option, the wiring is made so that a jumper harness could be installed to use the switch. Make sure that the wire from the gauge to the harness is plugged in. If this is the same Bronco from your post about dual tanks/ no switch, It may be possible that they disconnected the wiring with the intent of adding a switch.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 01-14-2008, 01:35 PM
Thanks!
No Heat at the sending cause I checked it. I would think that the ground wouldnt matter with a test light!
  #5 (permalink)
Old 01-14-2008, 08:25 PM
RCrawler's Avatar
As long as the gator clip end has a good ground...
Since you don't have power at the sending unit, go back and check the input and output of the gauge.
Jason
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
