Unleaded gasoline?
Originally Posted by Primered 1966 f100
Does anyone agree with this guy?
http://en.allexperts.com/q/Classic-Antique-Car-2542/unleaded-gas.ht
It's a seven letter word for a classic car, and it doesn't begin with the letter L.
All the engines are L heads, with compression ratios of between 4, 5 and 6 to 1.
Now...can you compare flathead straight eights and V12's from the 1930's with today's cars?
I run the lead additive in my two Packards, one a straight 8, the other a V12.
It's either that or spend mega bucks for hardened valve seats....if the aluminum heads decide they want to come off the blocks without a fight.
Nothing...drive it as it is.
My 1965 F100 went thru a frame off restoration during 1981/85.
The seats were not changed.
The truck has 187,000 miles now. it had 150,000 miles when restored.
I've had no trouble since with burnt valves.
Wait till the engine needs work...then go with the hardened seats.
I have a 66 F100 with a 300 I6 with 649,00 miles (give or take a few) and with the exception of a broken piston skirt (pulled it apart, replaced the broken part and put it back together) it has had no major work done to it. Cancer got the sheet metal but the engine keeps running. Run it till it starts amking noise and then just run it faster...
