Has anyone used the commander with the Dp chip or used the commander as just a stand alone gauge system. I am just wanting to get some info on how accurite they are compared to analog gauges. Thanks for any imput.
Some of the Commanders have issues with reading the coolant temp correctly but for the most part they are accurate. After getting mine repaired, it reads within 2 degrees of what a scanner is picking up from the PCM. Boost is extremely close as well as transmission temp. I couldn't tell you how accurate the EGT is because I have nothing to compare it to.
Overall it's a nice unit, but the Edge Insight may be a better investment. I haven't heard anything bad about them yet.
how is the boost read with the commander. dose it get it from the pmc or do you tap into the boost like like an analog gauge. I've heard the arn't accurite when you add a chip and boost folier.
