Edge Evo - Dash pod redesigned????
Old 01-12-2008, 12:11 AM
cub129's Avatar
cub129
cub129 is offline
I was over on the Edge website the other day and noticed that all of the pics of the Evo for the 04-08 150's were in what apeared to be an updated dash pod.
Has Edge redesigned the pod, or were they just showing the pod for the S-Duty Additude module (or somethign else) in a generic photo???
If they have redesigned the pod I'd like to order one, as the one on the website looks much better than what mine came with 2 years ago.
BTW, I emailed the same ??? to Edge last week and haven't received a response.
Old 01-23-2008, 08:22 PM
Extreme Justice's Avatar
Extreme Justice
Extreme Justice is offline
Yes it's a new pod. Painted to match the Grey colour and has a rubber casing that the edge slips into, instead of plastic on plastic like the old pod.
Old 01-23-2008, 08:38 PM
KTMrider's Avatar
KTMrider
KTMrider is offline
Just put one in my 05 F150 SC, I actualy put it in in a car wash so I would have alot of light. It took me about 1/2 hr to instal. The new pod work's and look's great.
Old 01-24-2008, 08:22 AM
Xyzzy's Avatar
Xyzzy
Xyzzy is offline
Just installed. It almost matches my flint interior.
Old 01-24-2008, 10:21 AM
pvstansel's Avatar
pvstansel
pvstansel is offline
Followup question for Edge users w/ the dash pod.
I'm considering using the Edge dash pod to house another device (widescreen GPS). I realize there would be some customization, but wanted to see if it is even feasible. I wanted to see if I could get some quick dimensions from someone.
What is the width and height (estimated) of the Edge device itself?
What is the width and height (est) of the hole the Edge would set in (the dash pod hole)?
What is the width and height (est) of the dashpod (including the bezel)?
Thanks in advance.
Old 01-24-2008, 10:35 AM
04 FX4 Lineman's Avatar
04 FX4 Lineman
04 FX4 Lineman is offline
That looks really good can utell me does a piece of the dash snapoff then the pod snaps in it's place, also what functions u can monitor at the same time ie. tranny temp, water temp, oil pressure?????
Old 01-24-2008, 10:38 AM
DaMole's Avatar
DaMole
DaMole is offline
O man. Just when I said I was not going to spend anymore money right now on the truck and then yall go and show me this. I am going to have to see if they will sell it separate cause that looks 10 times better than the old one.
Old 02-16-2008, 01:12 PM
LACityFD's Avatar
LACityFD
LACityFD is offline
The color is still off....I have the old school black one, went to my local Dupont jobber store, they gave me a 1/2 pint of color matched grey for free and then i sprayed it. Perfect match.
Old 04-09-2008, 02:42 AM
XolieX's Avatar
XolieX
XolieX is offline
i don't see a single difference other than color from the black one i got today with the kit than the gray one pictured on this thread.
Old 04-09-2008, 03:14 AM
dadirtydogg's Avatar
dadirtydogg
dadirtydogg is offline
if u pull the ashtray out, the edge is a perfect fit. drilled a small hole in the back of plastic behind where the ashtray slips in and ran the cable behind. i prefer it to mounting on the dash, but that's just me
Old 04-09-2008, 08:40 AM
mattd17's Avatar
mattd17
mattd17 is offline
the mounting pod actually just sits on top of the dash pieces, so you dont remove any of the stock pieces.... then the cable just runs down to your OBDII port. after you install it a couple times, you will see that you can install or remove it in a matter of seconds..... its very easy. as for the monitors, you can watch up to 4 readings at a time, and you have about 15 to choose from, like..... oil temp, instant MPG, average MPG, battery voltage, fuel line psi, accelerator position, tranny temp, oil psi, water temp, cylinder head temp, and some others that i cant think of off the top of my head. plus, you can read and clear diagnostic codes, and also do 0-60 or 1/4 mile times.
Old 04-09-2008, 04:58 PM
SteelHorse08's Avatar
SteelHorse08
SteelHorse08 is offline
Why do you mention "after installing it a few times" for? Wouldn't you just install hook it up and be done with it? Iam new to what this is , and very interested in it as well so thats why Iam asking. But ya why would you want to disconnect for? Out of sight from thieves when parked, or what?
Old 04-09-2008, 05:03 PM
DriftinZ's Avatar
DriftinZ
DriftinZ is offline
Probley if you take it to the dealer for warrenty work. Dont think they'd be happy to see a programmer in the truck.
Old 04-09-2008, 05:17 PM
SteelHorse08
Dont know what the fuss is
Why is that having a programmar a big deal for? You have aftermarket air and exhaust and were not taking them off going to the dealer. Why?
Old 04-09-2008, 07:43 PM
mattd17's Avatar
mattd17
mattd17 is offline
yes, it is for the dealer..... and no mine here wouldnt be happy to see one.... their stingy like that. some guys on the boards have had good luck with the dealers being ok with the edge units... i havent tried to test them. but, the reason i dont leave it in there, and my aftermarket exhaust stays on is simple.... they have to prove that the modification caused the problem.... that being said, exhaust is very unlikely to cause a problem, but a programmer could if used incorrectly. so, by removing the edge, there is no possibility that they could try to falsely blame the edge for anything !!!
Wvstream71
Computer Chips & Tuners
08-30-2015 02:21 PM
Wvstream71
08-30-2015 06:15 AM
golfmedik
6.7L Power Stroke Diesel
21
12-02-2013 09:55 AM
BURNSTOUGHFORD
1997 - 2003 F150
10-28-2012 11:32 PM
Quick Reply: Edge Evo - Dash pod redesigned????
