what's the difference in the clutch between a stock 3 finger (i dont know the proper name) or diaphragm style clutch compared to what L and L gives you in their kit? is their flywheel a custom setup, like a 390 turned down for the input shaft?
also, has anyone ran a serpentine belt setup in a late 70's 4x4 with a 460?
im trying to piece toghther my own setup and not buy thing that i dont need and see what price difference it would be to get the L and L kit or try to do it myself.
__________________
New Plan...
410ci, 10:1, AFD 57cc 2v Heads, Edelbrock Intake and Phenolic Spacer, 725 cfm Road Demon, Roller 219/222 @.050 .535 lift 108 lsa, Bee-Hives, Dual Roller Chain, ARP's, MSD Pro Billet, Hedman Headers, Milodon Pan and HV Water Pump.
There's not a whole lot of 'custom' parts in L and Ls kit, maybe the motor mounts and thats about it, but you can get those elsewhere for cheaper. Jeg's sells them for considerably less I believe, and you can get them on ebay also. Just my .02
Also, the IROKs are actually a perty good all around tire, they actually do good in the mud. I am a bogger fan myself. Sorry for the hijacking jbradley
ran into a little glitch today with my swap,when I step on clutch pedal,I cant get the clutch to disengage with pressure plate,I have'nt figured it out yet
i had that happen from my truck sitting, the clutch disk gets stuck to the flywheel.. somtimes you have to put a screwdriver between the 2 and pry some.
the parts are new,and I just assembled them 4-5 weeks ago,but I'll check that out.Another thing I have to consider is the 2" body lift,how it changed the clutch linkage geometry.
