Sway Bar Bushing Part Number
This is my first post but I've been looking and learning on this site for the past year or so. Have fixed a lot of things on my pickup from the info provided by everyone. Thanks to all.
I have a 2002 7.3L F350 DRW 4X4. I have been trying to get the right parts to replace my front end link bushings and sway bar bushings. My buddy knocked the old ones out. I have looked over all of the posts about the different part numbers that folks have used and have had issues with. I ordered a set from Energy Suspension, but they were the wrong size.
I measured my sway bar and I believe it is 1 1/8 in dia. and my sway bar bushings are 2 1/2 in. tall. I would rather not just buy the end links. I want to be able to replace them as needed while I own my truck.
Could someone please let me know if my measurements are correct and what part number I would use from any vendor. Thanks.
Here is a link to Energy Suspension that might interest you>
http://www.energysuspensionparts.com...t=3856&mantp=1
this link will take you to the set I just purchased
http://www.energysuspensionparts.com...E5186&cat=3856
and installed yesterday and everything fit perfect.
HOLD ON!!!!!!!!! I've already done research on this very same thing! I also have a 2002 F-350 4X4 dually and our front and rear sway bars are smaller than the SRW F-350s. The part number that these guys have given you is for a 32mm sway bar and end link bushings. The end link bushings will work but not the sway bar bushings. Dually front and rear sway bars are 27mm (1 1/16 inch) NOT 32mm (1 1/4 inch)!
I have already contacted 2 different techs with Energy Suspension and they do not offer sway bar bushings for a 27mm (1 1/16 inch) that are the right size for our application. The universal bushings will not work either! I'm actually considering buying a 32mm sway bar.
If anyone has found a non-rubber replacement sway bar bushing that is 27mm and will fit out application, please let me know!
I went to the dealer and bought mine for 67.00 each. They are the big ones. The parts house gave me the little ones that were around 27.00 each. I matched them to my truck in the parking lot and they were way too small. Now I have a spare set to put bushings in, if they make them. Dealer said they were not repairable.
brk300
07-15-2016 12:51 PM
Chevmn56
30
11-01-2015 07:51 AM
