Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-11-2008, 06:02 PM
greggraymo is starting off with a positive reputation.
Suggestions for rust under truck
I recently bought a 2000 F250 up in Michigan. Needless to say, there is some rust underneath that I would like to do something about. The exterior of the truck is in mint condition, but when you look under the wheel wells, you can see rust spots. It is an eyesore and I would like to get it back to the original black color. Does anyone have suggestions for the way to go about doing this? Is it something that an "automobile idiot" such as myself can do or should I just have it done professionally?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-17-2008, 02:52 PM
randomhero1172 is gaining momentum as a positive member of FTE.randomhero1172 is gaining momentum as a positive member of FTE.
Hey there Michigander!I recently purchased a truck with the same problem as you. doing some research i came across a product called POR-15, Its expensive but it works good and lasts long. My plans were to sand down the surface rust, treat the metal with the primer product and paint the frame and rusted parts. While your down there make sure to paint your oil pan with the high heat version of POR-15. If you get a leak in that bad boy its alot of headache!!!!! to replace the oil pan on a diesel super duty you have to lift the engine. in short its a $2000 job. Goodluck!
__________________
- Joe
2002 f-250 CC long bed 7.3 PSD - 295,000mi: 6637, Zoodad, Foil Delete,Silverstar Ultras, CCV, 5" MKO Strait Pipe, Cab Lights, WW.
NEW!!!! - 1990 f-350 dually 7.3 IDI 12ft Alum. Boc. 197,000. A little shaky
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
