Battery pics and ground strap question
If you really need a pic I can shovel the snow off mine and get you one(there is about a foot on it right now) but the negative cable just runs to a bolt on the lower right front of the block, there's a couple holes you can use, mine is in the lowest one. as for the positive cable it is a short one to the relay then from there runs pretty straight to the frame and around the motor mount and back to the starter,( I may have moved it to around the front of the mount to keep it away from the headers) and the ground strap is about 8 inches long or so and runs from the same bolt as the cruise control bracket on the upper rear left head and just to the firewall right close by. so if you don't get a pic by tommorrow I will shovel it off and take a pic for you if you still need it. Hope it helps Dan
also the strap is about one inch wide and flat, just a braided strap is all with eyelets crimped on each end
Ryan Weaver
11-21-2015 04:38 AM
gman97005
08-15-2015 04:14 PM
