Carb issues on my 460
I picked up a 1985 F250 w/460 engine. The truck wouldn't start and is sounded tile it was not getting enough gas. I have a buddy that said it seemed like the thermostat in the carb was not keeping the choke closed until it warms up. Sure enough, the choke opens right away. So I got a thermostat from NAPA for $100. I installed it, but I don't think that is the problem.
It has a holly carb and before I install a manual choke, I would like to know if there are any suggestions. I know the manual choke would be the quick fix, but I would rather do it right if I can. I am sure this has been discussed here before, but using words like carb, choke, etc. in the search engine gives too many threads to sift through.
Thanks, Bobby
Thanks, Bobby
First you need to determine if the carb is the stock Ford 4180 made by Holley or an after market Holley. The stock carb is and emissions carb and if it is they have a number of problems. What does not getting enough gas sound like? The choke heater (not thermostat) can cause starting problems but as long as the choke plate closes when the engine is cold and opens slowly after start up then it isn't the issue. Check the fuel filters. Check the float level. How do you know it isn't an ignition problem.
It is the 4180. "Number of problems" eh? That sounds promissing.
The plate does not open slowly, it jumps open when I start it up (or rather try to start it). My understanding is (and I could be wrong) the coiled spring inside the carb thermostat (this is what NAPA called it) slowly opens as it gets hotter, and in doing so it opens the carb plate letting in more air.
When I hold the plate close to restrict air into the carb, it runs fine. So when replacing the 4180, what are most guys going with?
Thanks!
Thanks!
Thanks!
Thanks!
http://www.holley.com/data/Products/...199R7948-5.pdf
I got the truck running and ran for a while, but then the engine seized. I sold the truck, but I do have a couple parts left over that I posted on ebay. If any of you guys want them, I'll cover shipping.
Thanks, cleveland
eBay Motors: Edelbrock 4 Barrel Carburetor w/14" Chrome Air Filter! (item 290267416171 end time Oct-22-08 21:12:31 PDT)
eBay Motors: FUEL PUMP Ford F250 F350 E250 E350 Econoline / Pick Up (item 290267418339 end time Oct-22-08 21:44:30 PDT)
Thanks, cleveland
PA F250
07-25-2014 08:19 PM
pffan021
10-12-2008 03:57 PM
towmater
07-27-2007 12:08 PM
pbuffing
10-03-2005 02:13 AM
1985, 4180, 460, adjustment, carb, carboretor, choke, f250, f350, ford, holley, issues, seans, seized, understanding
