remote pump for 289
remote pump for 289
I want to install a remote water pump on my 289 to reduce drag on my crank and make room for an electric fan, cause space is very limited between my pump and rad.
And I have plans in the future to swap in a 600 HP S.B.F. engine.
2 Questions.
What G.P.M. of pump would be sufficient to cool 600HP?
Where could I find the "AN" fittings to bolt onto the engine block, where the stock water pump used to be, that would be large enough to accommodate the pump as well?
Thanks
2 Questions.
Thanks
50 GPM should do well, you don't need to be able to move the water as much as quickly cool what's in the radiator.
For the fittings, I have never seen an adapter for SBF. You could probably make some block off plates and drill/tap them for a NPT/AN adapter. What I am thinking is flat plates that bolt the water passages, drilled and tapped so they accept an adapter, seal with gaskets and tef-tape.
Your choices seem to be 12 or 16 AN, AN numbers are 16ths of an inch so 16 an is 1" and 12 an is 3/4". Either should do as long as you can attach it to the rad.
alittle40
11-26-2010 07:44 AM
Michigan Rick
10-02-2009 01:23 PM
imlowr2
32
09-02-2008 05:39 PM
