Rancho RS9000XL Best improvement I've made - Ford Truck Enthusiasts Forums
Old 11-03-2014, 08:42 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Old 01-10-2008, 09:43 PM
cyerger57's Avatar
cyerger57 cyerger57 is offline
cyerger57 is starting off with a positive reputation.
Smile Rancho RS9000XL Best improvement I've made
Gentlemen, Just put on a set of Rancho RS9000XL Shocks on the front of my 1999 F-350 and what a difference. My truck is lifted 4" with a Superlift kit and it just about busted my kidneys. I never thought that having a new set of good shocks on the front could make this much of a difference. These things are adjustable for what kind of ride you would like and I set them at different settings to test it out. For on the road I set them at the second lightest setting and it just smoothed out the ride completely. My wife doesn't mind riding in the truck anymore. I highly reccomend them. They are worth the extra money. Just thought maybe someone would like to hear a review.
Old 01-11-2008, 04:34 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
I am considering them, I have a leveling kit that harshened up my ride just a bit. IT was pretty bad to start with and the extra spring didn't help.
Old 01-11-2008, 05:47 AM
cyerger57's Avatar
Harsh wasn't even a good word for the ride in my truck. I actually think it was shortening the life of the truck with all the hard "jarring". The truck is still no Caddilac but it sure is a lot nicer than it was. I just never thought a set of shocks could make that much of a difference.
Old 01-11-2008, 01:11 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
What is your tire pressure?
Old 01-11-2008, 02:43 PM
cyerger57's Avatar
I run Nitto Terra Grappler 285/65R18's at about 68-72 lbs for over the road. I only air them down when I know we're going to be doing a lot of snow or mud driving. I like the pressure high because it seems that there is less "wandering" of the front end on the freeway.
Old 01-11-2008, 03:18 PM
Quote:
That explains the harsh ride.
Old 01-11-2008, 04:36 PM
cyerger57's Avatar
Nope, I'm sorry sir but before these tires I had on a set of Pro Comps and ran them at 55-60 lbs and it rode just as hard. This was a night and day difference between the old shocks and the new shocks without changing the tires or pressure at all. The old shocks were also Rancho's but they were worn out and were not the right shock for the truck. Anyone that says these aren't worth the money either hasn't tried them, or thier truck is just plain different than mine. I'm not trying to convince anyone of anything, just giving a review of my experiance.
Old 01-11-2008, 06:41 PM
I'm not saying that the shocks don't make the difference. I'm saying that your tires are probably way overinflated.
Old 01-11-2008, 07:15 PM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
Any Decent shock absorbers will help smooth out the ride. I tried out the 9000's on my '95 F-250 and they worked OK until they were exposed to their first Connecticut winter. The salt spray caused the adjustment ***** to rust up solid.
I installed a second set of 9000's and two years later the adjustment was no longer adjustable. The 9000's got replaced with a set of Skyjackers (non-adjustable) and those shocks worked just fine.
If you drive in an environment where the roads do not get salted, the 9000's will work just fine. Otherwise just go with decent standard shocks.
Lou Braun
Old 01-12-2008, 11:08 AM
Thats good to know, no salt here, just sand. I run 285/75R17 Toyo Open country tires, recommended pressure is 80psi. I usually run tham at 60psi to help absorb some shock. I bump them up to 80psi if I am hauling though.
Rancho RS9000XL Reviews wanted !! Boston ballbagga 2004 - 2008 F150 3 04-16-2016 07:13 AM
Rancho RS9000XL shock settings johnsonjf Excursion - King of SUVs 9 11-01-2015 10:10 AM
Rancho RS9000xl shock deal! wildcat421 1999 to 2016 Super Duty 12 03-07-2014 05:44 PM
Rancho shocks on E350? Killer RC 1968-2013 Full Size Vans 8 04-13-2011 12:23 AM
RS9000XL or Bilsteins??? rayrayyj 1999 to 2016 Super Duty 86 07-16-2010 08:48 AM
Tags
1993, 2003, 4x4, 9000s, absorber, f250, instructions, rancho, review, reviews, rs9000xl, set, settings, shock, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
