Need some help...My red theft light flashes continuously after the expy starts. After about one minute it cycles through two slow flashes then five rapid flashes. It eventually stops. The truck runs fine. Also, three days ago my odometer went out for a few seconds and then came back on. It did this two years ago and I re-soldered the bad connection on the back of the instrument panel (as outlined in this forum). I have not had a problem with the odometer since. Idon't know if the two situations are related. Any thoughts? Should I run a HEC dealer test?
I wouldn't do what madson is suggesting. What if you can't start your truck due to the glitch in the anti-theft after you reconnect your battery? I would find out exactly what that code means before trying random "solutions?"
Thanks for the replies. It is greatly appreciated. One more piece of info. The flashing theft light doesn't always happen. It's inconsistent. I've been trying to find a pattern (cold v warm engine, cold v. warm day....).
another update..this morning my car would not start. Lights flashed and it sounded like several relays were clicking. I tried my second set of keys...no go. I disconnected the battery, waited, and tried again. Nothing. Pushed it out of the garage (great workout!) and towed to dealer. The result.........a bad battery cable harness and $300.
