77-79 f-250 bolt pattern
ive got a 89 bronco but it has been swapped out with 77-79 d44hd and a dana 60. all 8 lug out of a f-250.
im in need of new rims and need to know the bolt pattern. any help would be appreciated. thanks
and i was also wondering what is a good back spacing for a 36-12.5-16.5 tire
2 of the big 3 still use this pattern today. 1 (who will go un-named) had a metric brain fart and changed things up
As others mentioned you will have tons of wheel options - just stay away from 8x170mm rims off 98+ ford F-250's and 350's - unless you find a set cheap enough to justify the $150 or so to change the lug pattern.
upsfordman
10-19-2005 12:42 PM
upsfordman
10-08-2005 11:21 PM
