77-79 f-250 bolt pattern - Ford Truck Enthusiasts Forums
Old 01-09-2008, 08:40 PM
bronco1989 bronco1989 is offline
bronco1989 is starting off with a positive reputation.
ive got a 89 bronco but it has been swapped out with 77-79 d44hd and a dana 60. all 8 lug out of a f-250.
im in need of new rims and need to know the bolt pattern. any help would be appreciated. thanks
and i was also wondering what is a good back spacing for a 36-12.5-16.5 tire
Old 01-09-2008, 08:47 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
8 on 6 1/2" Plenty out there for it
Old 01-09-2008, 08:53 PM
cheapest ive seen i about $79 a wheel. im just looking for a black stealie style rim.
Old 01-09-2008, 11:17 PM
unrulee's Avatar
unrulee unrulee is offline
unrulee is gaining momentum as a positive member of FTE.unrulee is gaining momentum as a positive member of FTE.
The big three have all used that pattern. You have alot of options availible.
Old 01-10-2008, 02:08 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
2 of the big 3 still use this pattern today. 1 (who will go un-named) had a metric brain fart and changed things up
As others mentioned you will have tons of wheel options - just stay away from 8x170mm rims off 98+ ford F-250's and 350's - unless you find a set cheap enough to justify the $150 or so to change the lug pattern.
Old 01-11-2008, 08:03 PM
any cheap places to get rims. its only for offroad use so i dont care about looks.
Old 01-11-2008, 08:06 PM
craigslist, the classifieds here, eBay, etc. Just look around for used ones if you're "cheap" like me
Wanted 77 f150 4x4 leaf springs Kelowna area tobra British Columbia 2 03-11-2015 02:08 PM
wtb: used Skyjacker FA325 Pitman Arm 77-79 F-250 Pickup F-350 Pickup lisagoud WTB - Parts & other 0 04-15-2014 05:57 PM
need ft. crossmember 76-79 f100 4x4 or 77-79 bronco skyranch 1973 - 1979 F-100 & Larger F-Series Trucks 0 02-24-2014 03:05 PM
1975 f-100 power steering gear box change upsfordman 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-19-2005 01:42 PM
1975 F-100 Power Steering Gear Box Change upsfordman 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-09-2005 12:21 AM
Tags
1970, 1974, 1979, 350, 77, 79, 98, bolt, f100, f250, f350, ford, lug, pattern, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
