Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-09-2008, 04:49 PM
mjz1's Avatar
mjz1 is starting off with a positive reputation.
87 BroncoII Trans Swap?
Hello I have a 87 BroncoII eb with a 2.9L engine. (engine blown Good trans w/OD)
I would like to know if this trans will work in a 1985 BroncoII with a 2.8L engine (bad trans, great engine)
are these parts interchangable?
Thanks Mark
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 06:28 PM
mrshorty is starting off with a positive reputation.
Automatic or manual transmission?
If automatic, the '87 will have an A4LD, and it should only have one solenoid in the valve body (I'd double check to make sure, it seems like '88 was the first year for the 2 solenoid valve body in the A4LD).
'85 was the first year for the A4LD. Make sure your '85 doesn't for some reason have a C3 or other 3 speed transmission. If they are both A4LD's with one solenoid, they will be direct replacements.
If manual:
A TK5 should swap for a TK5 and an FM145 should swap for an FM145. I'm not sure which is more likely in the '87, but I expect the '85 would be the TK5.
In either case, the best first step would be to positively identify which transmission is in each. There's a good chance they both have the same transmission and will swap just fine.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 01-09-2008, 06:57 PM
mjz1's Avatar
Auto Trans, The 87 has a 3+OD, and the 85 has a 3 speed auto, no OD.
I was hoping the 3+OD would just bolt onto the 2.8L
  #4 (permalink)
Old 01-10-2008, 12:19 AM
The bellhousing bolt pattern is the same, but I'm not sure about transmission length. You may have to move the crossmember and adjust the length(s) of the driveshaft(s).
Assuming your '87 is the expected one solenoid valve body, 4th gear is vacuum controlled, but you won't have the lockup torque converter clutch unless you figure out the wiring for it.
__________________
  #5 (permalink)
Old 01-11-2008, 10:44 AM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
the a4ld is longer that the C5
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
