Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-09-2008, 04:09 PM
Frankenstang57's Avatar
Frankenstang57 is starting off with a positive reputation.
v-8 swap?
Quick question for you guys, if there is a thread or tech article on this please show me the way... Otherwise, how hard is it swap a 302 into an early I-6 Bronco? Will it bolt up to the existing trans? I'm not too worried about exhaust/plumbing/wiring. Just curious, I may be doing a swap for a friend. Thanx!
__________________
FRANKENSTANG57
06 Ranger
96 F250 4x4
70 Bronco
June 4th is Marvin Heemeyer day!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 08:41 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
There aren't any tech FAQ's for the early Bronco. There has been talk for quite a while to make something up.
You will need to buy V8 engine towers to weld into place. They are readily available through the Bronco specialty shops. You will need a V8 bellhousing, and a V8 transmission along with the corresponding transfer case adaptor (or a good time to upgrade to a 4 or 5 speed). The 6 cyl transmission will not hold up to the torque of a V8. You also need the clutch linkage from the frame to the bellhousing.
Radiator, throttle linkage...
HTH,
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 01-11-2008, 12:42 PM
Thanks for the input. We're not looking to anything too radical here. It appears Ford only offered 2 transmissions, the 3spd manual and the c-4 on later models. They used the same d-20 t-case on all of them. I don't know if the c-4 was offered with the I-6 or not, but the same drive train was used in both v-8 and I-6 models. Only difference is the length of the intermediate shaft and housing due to the length difference of the 2 motors. same length d-shafts, same x-member, etc. Sounds pretty easy to me. I guess the c-4 intermediate shaft adapter is pretty rare and or expensive tho. Thanx again.
__________________
FRANKENSTANG57
06 Ranger
96 F250 4x4
70 Bronco
  #4 (permalink)
Old 01-13-2008, 09:49 PM
RCrawler's Avatar
The auto only came behind V8's. So there is only one adaptor for it.
There were 3 different versions of the 3 speed: the 6 cyl, the light duty V8 and the HD V8. Which means there are 3 different intermediate shafts and adaptors for them.
From the transfer case back, they are the basically the same. There are 2 different transfer cases with different shifter types and gear ratios. They will interchange as long as you have the corresponding shifter.
Jason
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
