Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-09-2008, 03:48 PM
hotrodmerc's Avatar
hotrodmerc is starting off with a positive reputation.
slight surge and low power
I have an 88 BII 2.9 auto. Just changed the v cover gaskets and now it is kinda surging and seems to have less power under acceleration. Checked all vac. lines and wires all were ok. Anyone have any ideas before I dig into it?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 03:57 PM
Help I M Stuck is starting off with a positive reputation.
clogged cat converter?
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #3 (permalink)
Old 01-09-2008, 04:40 PM
hotrodmerc's Avatar
I haven't noticed it getting hot but it did cross my mind.
  #4 (permalink)
Old 01-11-2008, 12:42 PM
allentire is starting off with a positive reputation.
bronco 2 hesataion and power loss
you have 2 fuel pumps in that bronco the one in the tank is the one that needs to be replaced of you are haveing problems accelerating and hesatation,check fuel preassure the one on the chassis is the primary pump the pump in the tank is the pick up pump...the pumps are the exact same so if you can go to a salvage yard and pick one up that would prob. fix the problem...hope it is the info you need
  #5 (permalink)
Old 01-11-2008, 10:49 PM
Lead Head is gaining momentum as a positive member of FTE.Lead Head is gaining momentum as a positive member of FTE.
Possibly a clogged fuel filter. Hook a pressure guage upto the valve on the fuel valve, should be around 35-40 PSI
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
