1994 Ranger and OBD II compatiblity - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-09-2008, 12:19 PM
Skarr Skarr is offline
Skarr is starting off with a positive reputation.
Greetings!
Is the 1994 Ranger fully compliant or partially compliant with the OBD II protocol? I've seen various information stating that 1994 might have been a transition year for OBD II and therefore some or all of the data may not be accessible through OBD II. I think model year 1996 was the year that all cars were required to use OBD II, but 1994 and 1995 are a little fuzzy.
Is OBD I the precursor to OBD II? And would a 1994 Ranger use OBD I codes?
Finally, will an OBD II scanner read OBD I codes?
Thanks!
Old 01-09-2008, 12:29 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
'94 is OBD-I, or rather, EEC-IV
'95 was a transition year, you could get either EEC-IV or OBD-II in the Ranger.
'96, OBD-II was required
OBD-I/EEC-IV is the precursor to OBD-II, yes.
A '94 Ranger uses OBD-I/EEC-IV codes.
Most OBD-II scanners will not read EEC-IV codes without some sort of adaptor, and even then only the high end ones. But EEC-IV scanners are cheap and easy to find.
Old 01-09-2008, 01:02 PM
Thanks, RP!
OBD I or OBD II?? mike21105 Ranger & B-Series 5 09-08-2016 02:18 PM
Scan Tool for 96 F250 Diesel (Non-OBD-II Compliant) XFORMR 1987 - 1996 F150 & Larger F-Series Trucks 5 12-08-2015 07:33 AM
OBD-II ?? kountzecobra 1968-2013 Full Size Vans 2 06-05-2014 10:16 PM
OBD-I or OBD-II?????? meck1 Ranger & B-Series 4 05-11-2007 04:42 AM
95 Ranger OBD II Code Reader hreed Ranger & B-Series 5 12-04-2003 10:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
