Brite Box with HID - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Brite Box with HID
Old 01-09-2008, 10:21 AM
4DPLAY 4DPLAY is offline
4DPLAY is starting off with a positive reputation.
Brite Box with HID
Has anyone tried the brite box and a hid conversion kit? I am thinking it might be too hot for the lens. Any info would be appreciated.
Old 01-09-2008, 10:37 AM
dabears2k's Avatar
dabears2k dabears2k is offline
dabears2k is starting off with a positive reputation.
All of the HID kits offered at www.dabears2k.com are 3x or 6x (35w or 55w) brighter than stock headlights and yet burn cooler than stock headlights.
Our HID kits are guaranteed to not melt the headlight lens.
http://www.dabears2k.com
Old 01-09-2008, 10:43 AM
so a guy could run highs and lows with 55watt hids at the same time and should be ok?
Old 01-09-2008, 10:48 AM
dabears2k's Avatar
if you run the wiring harness that is optional with my 55w kit, you will be fine. let me know if you have other questions.
Don't forget, ordering from Dabears2k.com, if we reach 5 orders, everyone gets $5 off
http://www.ford-trucks.com/forums/69...31-2008-a.html
Old 01-09-2008, 10:54 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Quote:
The way hi/lo HID's work, you won't get any advantage with the bright box and will just be wasting money with it.
Standard bulbs have 2 filaments. Normally one is on for high and one is on for low. The bright box runs both filaments on high, giving you more light.
With HID hi/lo's, there is only one bulb and there is no filament. Hi/lo beam is achieved by mechanically moving the bulb. Since the bulb can't be in two places at once, it can't run high and low at the same time.
Old 01-09-2008, 10:56 AM
dabears2k's Avatar
Ah, thank you for clarifying what a bright box is.
You will get better performance by going with an HID kit on standard headlights than going to a brightbox and running halogens.
Like I said, the HID kit will not melt the housing and will give you up to 6x as much light as stock halogens.
Old 01-09-2008, 11:00 AM
Thanks dchamberlain, I'll just stick with the brite box.
2004 f250 5.4 engine, fuel pump relay location landscaper62 1999 to 2016 Super Duty 6 12-18-2016 11:21 AM
Best/easiest access to replace headlight bulbs? DawnPatrol 6.0L Power Stroke Diesel 5 11-20-2015 10:34 PM
brite box vs. new projector housings Justin03PSD 1999 - 2003 7.3L Power Stroke Diesel 11 11-03-2013 10:45 AM
DIY: Vehicle Rim Cleaning (Vid Tutorial) ProStreetDriver Appearance & Dress-Up 0 07-03-2013 12:40 PM
Brite Box from Inovadd STEVES68NOVA 1999 to 2016 Super Duty 3 04-05-2013 07:07 AM
Tags
2006, box, bright, britebox, dabears2k, f250, ford, headlamps, headlights, hid, lenses, lighting, melt, reviews, standard, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
