Anybody mount a 50's F100 body on a 78-79 Bronco chassis?
#46
Terry, that reminds me of one a friend of mine here built. There is a yearly competition put on by Grassroots Motorsports magazine called the $200x (x = year of each competition, started in 2000) Challenge. You must build a complete car with a documented cost of less than $200x.00 based on a production car, bring it to FL and compete with it in a 1/4mi drag race, autocross, appearance/engineering judging.
His car was a Mustang body grafted to a Toyota Supra Chassis with the Mustang 289 engine and manual tranny. The combination was surprisingly easy as the M & S had almost identical WB, track width and F-R overhangs. He called it a Suprang. It did not win due to tranny failure during drag race competition but he brought it to several local AXs, it was fast and handled very well.
#47
on
1 Post
Hey AX, that sounds COOL, you got any pics? The reason we did it on a Mustang chassis, is I wanted to keep it all FORD. I made a mistake on my F100, and I dont want to do it again. The biggest problem we had, was when he got his new wheels off an 03 Mustang, they are 17x8. The '95 up cars were 2" wider in the front!! Which was really noticeable. We thought about fender flares and all kinds of goofy stuff, but finally found out that an older FOX body had narrower A-frames, which pulled the wheels in a total of 3 " now the wheels set under the fenders! I had to cut the strut tower and lean it in to get the camber back, but that was no big deal.
The car is commin along great now. Maybe we'll have more pics soon?
#48
http://suprang.com/
He used the Supra chassis to get the better handling IRS and better balance for AX.
#49
I Like your truck I am very interested in that conversion
Originally Posted by irondragon79
I'm in the process of doing a 4x4 conversion on my 52' F-3. I looked at the potential of using a late 70's F-150 frame, but I actually opted to stick with the stock frame and swap over the 4x4 components.
I'm using a late 70's 460, C-6/NP205 out of a 79 Bronco (although I am debating about using a NP435 4sp manual tranny).
For axles I have a rear Dana 60 out of a 1969 F-250, and I will be narrowing a Dana 44HD out of a 1977 F-250 to fit under the front.
#50
Originally Posted by 3fordf1
Hi I like that extra cab 4x4 I was wanting to do the same to mine, Do you have more info that you could give me ? 3fordf1 THANKS.
#51
Hey Fordman, you want to see a "frame swap" to the EXTREME, check out my gallery under ReinCARnation. It's my buddy's '68 Mustang coupe, we cut out the firewall, and floor. Then we cut up a '95 Mustang GT and kept the floor, firewall, and all the suspension. We put the two together! We had to add 7" to the GT to make the '68 fit.
I understand Terry's going to graft a Yugo on a Borgward frame, next...
R
#52
frame swap
Yes, I have successfully done a Bronco frame swap.In the late 90's I put a 78 Bronco frame and drivetrain under a 56 F100.Took me about 6 months weekends and evenings including the bodywork and paint.The guy I sold it to is still driving the truck to this day.I also have done numerous frame swaps.And found the bronco frame swap to be easiest one I've ever done.I don't find frame swaps any more difficult than adding late model steering, brakes,engine mounts,gas tank mounts,etc.I don't know why you guys always think it's so hard doing a frame swap.I wish I knew how to post pictures.But if you need any info I can pm you with all the details on doing the Bronco frame swap.
However that being said the truck will have a very rough ride when your done.
The 56 body is a little light for the Bronco suspension.
#53
https://www.ford-trucks.com/forums/6...-pictures.html
Post some pictures, I would like to see how you did it.
#54
#55
A rough ride is not an issue for me. I'm use to driving 3/4 and 1 ton trucks for my daily drivers. This is a 4x4 I don't expect it to ride like a Lincoln!
Ok here's a side shot of the truck Herman built:
Here's a chopped pic that is a rough guess of what it would look like on a stock Bronco chassis:
It looks different but I don't think it looks too bad.
#59
i was chatting with a guy on another forum and he seen pics of mine and liked it and said he's got a buddy who has another 53 that he put on i beleive a 75 3/4 ton ford van frame sometime in the early 80's drove it and it has been sitting for quite some time , but still runs / driveable . i think chip is gonna buy it for 3500 and roll with it . i am gonna ask him for pics preferably e-mail so i can try and drag 'em over here . oh and this fella has built and owns some dain fine rods so i know he's not full of it .
