Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-09-2008, 12:32 AM
Wiseguy150 is starting off with a positive reputation.
Bronco help asap
I am currently looking around for an early bronco to build up very slowly and use to drive when roads are not so great to keep my truck and car nice. I dont know a lot about them and am wondering if any one could tell me if there is anything I should know? I really want a manual shift on the floor. I t hink I have found 1 that is but am not even sure that a floor shift exists. I also see some have strange back fenders that give no clearance for tires. I do not want one with cut fenders but I dont want one like this either. I think it is possible part of the sport package but not sure. Any help would be great. I am looking at one now that seems like it may be exactly what I want so Im hoping for some feedback soon.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 12:58 AM
73azbronco is starting off with a positive reputation.
I advise you to find a good quality used Toyota/Jeep/Nissan 4x4. It will cost you less and last alot longer. Early Bronco's have become collectors items, and getting one in the shape I think you want, will either cost you about $15,000 to buy in good shape, or cost you that to get it in shape.
Best of luck, you may find a sleeper out there. it took me 9 months of internet searching anything out west to find an uncut, rust free, mostly original 73 for $9000. It will get about $10,000 in makeover in the next few years...
  #3 (permalink)
Old 01-09-2008, 01:12 AM
I think I found one for 3200 in reasonable shape. Uncut soposadly running. Everything is there and a color I like a lot with the hard top that I want. I am deffinitly not interested in anything but a Bronco. I agree with you 100 percent but I would just keep my pickup only before I would buy a jeep or foreign vehicle. It seems from what Ive seen parts are fairly abundant for them as far as interior and body parts.
  #4 (permalink)
Old 01-09-2008, 01:59 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
You can still find really nice, unmolested, rust free Broncos for under $5K. Just have to do your homework and be patient.
Most of the high dollar ones are either way overpriced junk, or too nice to drive. I paid 3800 for my '69. Rust free and uncut, completely original except for the wheels. A few years after that, I bought a fully optioned (but cut out fenders) 76 for $3900. I see them now in that condition for $5-7K, so they can be had.
Originally, all Bronco's came with either a column shift 3 speed manual or a column shift automatic. 68-72 have a transfer case shifter with a push button t handle that resembles a floor shifter.
Converting the 3 speed to the floor is a common modification. Gives it a sporty look and makes for better shifting. They also have floor shift conversions for the automatics as well.
This is what the stock rear fenders look like.
This is a conservative looking cut out fender using Bushwacker flares. They are more durable than fiberglass.
Another trick way to open up the rear fenders is to graft in some front fender openings. Takes a lot of work and of course you will have to refinish the area. But if it is done right, it makes them look like what the factory should have done.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #5 (permalink)
Old 01-09-2008, 02:03 AM
So anything I see with a shifter on the floor can not be stock. Im looking at a 77 with a shifter on the floor and even a factory looking rubber boot around it.
  #6 (permalink)
Old 01-09-2008, 02:09 AM
RCrawler's Avatar
The transfer case shifter will be on the floor in all Broncos.
Jason
__________________
  #7 (permalink)
Old 01-09-2008, 02:15 AM
This one has two on the floor.
  #8 (permalink)
Old 01-09-2008, 03:09 AM
RCrawler's Avatar
The one closest to the driver is a 3 speed manual shifter and the other one is for the transfer case. If you're tall, the floor shift 3 speed can be a little uncomfortable. It gets in the way of your knee.
Jason
__________________
  #9 (permalink)
Old 01-09-2008, 10:23 PM
dodmort's Avatar
dodmort is starting off with a positive reputation.
I am 6'6" and just put my mount on my seat back a bit .
The hurst shifter is the way to go unless you want a 435 conversion.
very glad i got rid of the column shift on my 68.
can still put some agressive tread tires on stock fenders.
once they are cut then .............
  #10 (permalink)
Old 01-10-2008, 10:49 PM
fordtrucksforever is starting off with a positive reputation.
Quote:
Unless you just want to build one up and have something that will end up being worth too much to risk on bad roads, here is another suggestion.
An 86-91 Bronco II, the little ones are plentiful and dirt cheap. The 2.9 EFI motor has plenty of power. A 4X4 version with 5-speed is a good combination. With normal sized BFG All Terrian tires, these little beasts do extremely well on bad road conditions. On completely iced over roads, I have never driven anything that worked as well. The ttb front end is the ticket for decent drivability during bad weather. But this is only one persons opinion.
  #11 (permalink)
Old 01-11-2008, 12:45 AM
I completly agree with you. My dad had a 1990 Bronco II he bought brand new and drove it for 11 years. I just am in love with the old broncos. I wouldnt build it up very fast im talking years. And once I got it nice I wouldnt be using it for bad weather. Then id just have to buy another one and start the process over. I think I let the deal of a lifetime pass me up yesterday though. Its got me literally sick that I let this one slip by me.
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
  #12 (permalink)
Old 01-11-2008, 03:21 AM
Dont get into the mindset that each Bronco you miss out on would have been a deal of a lifetime. Especially ones sold on ebay. I bought my first and one in best condition 11 years ago. Since then I have acquired 5 more that were, I thought, deals of a lifetime. Or the fact that I had money at the right time. They are all great projects. Three are all together and running. One is currently a complete frame off ground up with an efi conversion. My first one is rust free and an original halfcab. It will get all the bells and whistles when finished. Currently I dont want to strip it down, knowing how long it will take to finish in the condition I want. My worst addition was one off ebay. It was a `77 fully loaded. Unfortunately the term "has some rust" was putting it mildly. Amazing how much better things appear, most of the time, in a pic. Even tho the information was not misleading, I inturpretted it in a more positive way. There are plenty of them out there. Just be patient and avoid anything that has a history in areas of the country where rust is common occurance. As many people that are trying to do restorations on these, most will never finish. These are the ones you need to be ready to snag up on.
  #13 (permalink)
Old 01-11-2008, 03:45 AM
Ya I am feeling a little better about it. I have been reading up on differences in years and looking around and they are out there if you make an effort to find them. Ill probably wait untill summer when I make some money to reallly make a good effort for one. I want to find one uncut that isnt nice and shinny but not full of rust holes either. The search to find the right one is half the fun I guess. If I buy anything early than a 75 am I going to have to get a lead additive to put in it?
  #14 (permalink)
Old 01-13-2008, 09:43 PM
RCrawler's Avatar
Quote:
Buy one, build how you want it and drive it. Doesn't matter how nice you make it, that's what it's for. What good is a museum piece that you can only take out on nice days? Especially something as multipurpose as an EB. I bought my first one almost 15 years ago. I've put way more money into it than it is worth to make it work like I want. Maybe someday I'll get my other projects gone and find time to make it nice and repaint it. But even with new paint, I'll never be afraid to take it out and get it muddy or dented a little. I've owned a couple of really nice, low mileage uncut stockers and I would never hesitate to drive them on bad days. But I would never do with them what I do with my '69 tho.
As far as the leaded gas question, I wouldn't worry much about it. Many that are still in service have had valve jobs with the hardened valve seats installed. If they haven't, there is a good chance that a valve job or major engine work is going to be needed in the future.
Jason
__________________
  #15 (permalink)
Old 01-14-2008, 11:31 PM
Can't make money? Not that I'm doing this for bucks, but this is a reason it's hard to find one for a decent price, check this out:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
