Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-09-2008, 12:16 AM
kennyhimself is starting off with a positive reputation.
my truck starts and stop immediately
my truck starts and truns off right away if i start it and hold my foot on the gas petal it will stay running but when i take it off it shuts off no check engain light and the scaner wont give me a code the guy at auto zone said it might be the mass air flow but i dont think so can any one help thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 12:45 AM
streethealer's Avatar
streethealer is starting off with a positive reputation.
Its a dirty or malfunctioning IAC valve is most likely your problem.
__________________
Kevin
1999 F-150 4x4 4.6L 3.55 F/R
In other words.....Bone Stock
I work on people for a living
  #3 (permalink)
Old 01-09-2008, 12:49 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
YEP, replace the IAC (Idle Air Control valve)
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 01-09-2008, 12:50 AM
where is it located and is it hard to clean? what dose it stand for
  #5 (permalink)
Old 01-09-2008, 12:57 AM
Quote:
4.7L or 5.4L?
__________________
Kevin
  #6 (permalink)
Old 01-09-2008, 12:58 AM
4.7 thanks
  #7 (permalink)
Old 01-09-2008, 01:08 AM
I'm sorry i meant 4.6L. Anyway on a 4.6l it is located on the drivers side of the throttle body under the 4.6l triton plastic cover. The cover has 3 8mm bolts that hold it on. then there it is. It is round on one end and has a type of triangle mounting flange wit 2 more 8mm bolts holding it on. It also has an electrical conector on the round part. You can clean it if you want with carb or brake cleaner to remove the carbon deposits from the inside, but it most likely will fail again. They are about 40-60 dollars to replace if you want to go that route. A 4.6l is much easier than the 5.4l by the way. I hope this helps you out... Good Luck.
__________________
Kevin
  #8 (permalink)
Old 01-09-2008, 01:50 AM
LxMan1's Avatar
It is here http://www.ford-trucks.com/user_gall...=99255&width=2
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #9 (permalink)
Old 01-09-2008, 01:59 AM
Jimmy, that's a good pic of a 5.4l IAC. I wish I had looked at it before I told my neighbor that I would change his for free on his 5.4. My 4.6l is different though. I've replaced them on both motors and the 4.6 is much easier because it is out in the open away from the firewall.
__________________
Kevin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
