How Much $ to Replace Head Gaskets? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-09-2008, 06:13 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
It can be done without pulling the engine or lifting the cab,( My dealer is doing it now to my wifes Excursion) but they had to remove the ac plenum on the pass. side IMHO It would be faster and easier on the back to pull the engine. Unless your an experienced tech, dont even think about attempting this job, If you make a mistake it could be alot more costly than having it done by a pro to begin with.Good luck and keep us posted.
Old 01-09-2008, 06:27 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Quote:
Originally Posted by Forest
Excursions are all of a piece--no separate cab.
That's right, I had forgot you had an excursion, I would say best bet is to pull the engine, some have attempted it without doing either of what I had mentioned, but I believe it's going to be easier to pull the engine. I wouldn't do it myself, but I'm not all that comfortable to doing that kind of job on my tractor(tractor maybe with a manual) but not my truck.
Old 01-09-2008, 09:37 PM
Forest's Avatar
Forest Forest is offline
Forest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to beholdForest is a splendid one to behold
I may be crazy, but I don't have enough time to do this. Otherwise, I probably would do it to save $2000 - $2600 (Ford dealer quote to replace gaskets with new Ford bolts).
OK. Further dumb question.
Can the head bolts be torqued in place without removing the heads? Would this accomplish anything? Break the bolts? Seal the gaskets? Are the bolt heads accessible?
Old 01-09-2008, 09:53 PM
tex25025's Avatar
If your leaking coolant, your heads are more then likely warped by now, if you don't machine the heads(if it isn't too bad, otherwise you'll have to replace the heads) then all this is for nothing because you'll have to come back later and redo this all over again(personal experiance right here). That is probably would it would cost a shade tree mechanic to do it and you would get studs which is far superior to the ford bolts.
Old 01-09-2008, 10:02 PM
Forest's Avatar
Yeah. I just need to find a good independent mechanic in Tulsa or nearby...
Old 01-09-2008, 10:22 PM
tex25025's Avatar
If worst comes to worse, I would think the dealership would install the studs for you, rather or not they will take the heads to be machined depends on how they do things like that, but it's all on your dime so I don't think they would squawk all that much about it.
Head Gasket Cost Baywatch13 6.0L Power Stroke Diesel 16 05-01-2012 03:17 PM
Intake Manifold Removal?????? mr.fordneck 1987 - 1996 F150 & Larger F-Series Trucks 5 02-17-2011 06:41 PM
head gasket? 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 52 11-29-2010 08:44 PM
damaged head gasket symptoms caprocker 6.0L Power Stroke Diesel 14 06-12-2010 05:27 PM
Head Gaskets 2.9 dyrbr_d 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 4 04-18-2005 03:09 PM
Tags
60, 60l, change, cost, diesel, excursion, f250, gaskets, head, headgasket, headgaskets, powerstroke, price, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
