Engine skipping? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Engine skipping?
Old 01-08-2008, 10:29 PM
F250SuperDoody F250SuperDoody is offline
F250SuperDoody is starting off with a positive reputation.
Engine skipping?
Hello, I just picked up a 99 F250 SuperDuty 5.4L with 140K on it. It drives pretty smooth, but has a hesitation under certain loads, particularly in OD on the highway up hills, and when I step on it. It kind of clears itself up though, back and forth. No Check Engine lights. I changed the plugs (OEM motorcraft), fuel filter, air filter, pcv valve, and oil changed. It still acts up. Any pointers?
E4OD not shifting into 3rd or 4th. AWSHUX 1987 - 1996 F150 & Larger F-Series Trucks 1 04-15-2015 06:01 PM
transmission stuck in drive always mdierking 1987 - 1996 F150 & Larger F-Series Trucks 15 03-02-2015 08:57 AM
F250-E4OD problem FN250super cab New Member Introductions 2 11-19-2014 02:08 AM
Drain plug on E4OD Converter?? wayneF250 1987 - 1996 F150 & Larger F-Series Trucks 9 04-17-2008 11:10 PM
aod hard shift into OD stoner51 Clutch, Transmission, Differential, Axle & Transfer Case 2 10-31-2003 12:05 PM
Tags
1977, 460, 60, diesel, engine, excursion, f250, ford, motor, skipping, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
