Tach not working !!! - Ford Truck Enthusiasts Forums
Old 01-08-2008, 03:28 PM
philbax's Avatar
philbax philbax is offline
philbax is starting off with a positive reputation.
I'm trying to figure out why my tach is not working correctly. When I start the engine up 351w EFI 87 F350. Tach acts like it wants to work as it goes up to around 600rpm and stays, then when I push gas peddle down tach goes to 0 and lower. Back ground : replaced 351w carb engine with 351w Efi changed all wiring under hood plus all wiring in cab, I kept original gauge cluster in truck but I do have a replacement from doner 351w EFI truck if there is a difference in them, all other sensors gauges seem to be working correctly. Any help would be great!
96 F150 converted to carb - how to fix tach? 408 Torquer 1987 - 1996 F150 & Larger F-Series Trucks 4 07-20-2014 10:05 AM
Another Factory Tach Question Old Hickory 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 02-26-2011 08:39 AM
Factory tach wiring questions. scottscott 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-22-2010 04:08 PM
Installing factory tach as if it was an aftermarket one. Big Red 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 08-24-2005 09:51 PM
VDO Gauge oft 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-24-2002 09:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
