I have an unusual (to me anyhow) intermittant problem with my 1996 7.3 PSD.
Every once in a while when trying to start it cold it acts like it's getting flooded. I have to repeatedly heat up the glow plugs and when it does finally fire it blows white smoke for a while. White smoke comes out the intake before it starts also.
Maybe your relay is shutting to quickly and not letting them heat properly. Hard to tell without seeing it. All glow plugs light? Did you do a wire test?
if your glow plugs are working when you turn the key and wait for the wait to start light the volt gauge will be pulled way down a lot. when they kick out it bounces back. my bet is it is the relay or the ground wire for them
I can hear the relay and the voltage is definitely down. I will check the wiring to the relay. I replaced it several years ago but maybe it is going to hell on me again.
