Check Engine Light
Check Engine Light
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have a 2002 Lightning that has the check engine light on because of the air raid intake i have in it. I took it to the dealer and they said the light is going off because the engine is running to lean. Could this be bad on the engine if i leave it? I also have flowmaster exhaust on it and i dont know if that could be setting the light off also. Any help on this would be nice, thanks.
</TD></TR></TBODY></TABLE>
Originally Posted by LostMayhem
It recieved codes P0171, P0174, P1229 Lean on banks 1 and 2. Im not sure what all of that means I would appretiate some help.
Is your MAF housing seated and sealed properly on the Air Raid housing?
If, when you check your IC pump you find it isn't working, take it out and clean it. A lot of guys have had good luck by cleaning the gunk from the pump.
Stewart
mjorda2
Electrical Systems/Wiring
12-13-2007 12:00 AM
