Bigger wheels/tires = decreased fuel mileage?
Hello, I have an '04 F250 6.0 diesel which still has stock wheels/tires. I want to upgrade to 20" wheels wrapped in Nitto Terra Grapplers 325/60/20. Will I see a big decrease in fuel mileage?
I currently get around 22 mpg freeway and 17.5 mpg average.\
Thanks
Thanks
Yes, any time you increase tire size (note I said tire, not wheel), then fuel mileage will drop. The amount of decreased mileage depends on tire size, tread, driving style, tire inflation, etc. Remember that you are raising the truck's height by putting bigger tires on, plus you are increasing the rolling resistance with the larger and heavier tires.
At highway speeds of 70-75, my mpg increased when I went to the 35" tires. The reason is, that I now run at less than 2000 rpms at those speeds. Before, I was at 2300 rpms. I have 4.30's and I had to go 60mph to maintain 2000 rpms. So on long trips I get better millage. In the city it is worse, since it takes more to the tires up to speed. This is all manually calculated.
Don't forget that a larger tire will show lower speed and less distance traveled over the same distance as a smaller tire. This has to be taken into account when calculating mileage. If you put a tire on that is 3.5% bigger in diameter then you have to multiply your MPG by 1.035 to get an apples-to-apples comparison to MPG with the smaller set. The same applies to indicated speed. When I went from the stock 265/75R16 tires to the Nitto 285/75R16 I thought I would have to make mental corrections for speed and mileage. I tracked indicated vs. GPS numbers over a 900 mile trip and found that the new tires were within half a mile over that distance and speed was dead on. I guess that's close enough for me.
I would agree with GwizRC - the larger tires should actually increase your mileage at highway cruising speeds. I went from 18" to 17" wheels on my '05 and the mileage went down 1-1.5 mpg, probably due to higher rpm. I switched back to the 18's recently but haven't really driven it far enough to verify the mileage is back up.
Of course, tread design comes into play as well. If you are going from an all season radial to an aggressive m/s tire than the extra resistance will probably eat up any gains.
Either way you shoud expect your stop and go mileage to drop due to the extra engine work required move the larger diameter tires.
Your mileage may go up or down, depending on a few things. It isn't all black and white.
First, larger tires usually have more rolling resistance. Your mileage will go down (all else being equal) by using tires with a higher rolling resistance. Using a skinnier tire will decrease the rolling resistance, but most guys want the wider tire look.
Second, larger tires will change the effective gearing. This may increase or decrease your mileage, depending on your engine. If the new effective gearing puts your engine into a sweet spot at cruising speed, you'll get more mileage. If the gearing puts the engine at an RPM where it has to burn more fuel to make the same power, mileage will go down.
[QUOTE=thedaddycat]Don't forget that a larger tire will show lower speed and less distance traveled over the same distance as a smaller tire. This has to be taken into account when calculating mileage. If you put a tire on that is 3.5% bigger in diameter then you have to multiply your MPG by 1.035 to get an apples-to-apples comparison to MPG with the smaller set. The same applies to indicated speed. QUOTE]
This is very important - If you don't make this correction, either with math, or by recalibrating your speedometer/odometer, your numbers will be meaningless. And you may be driving faster because your speedometer is not right, making the comparison even less apples to apples.
Originally Posted by Momorris
Has anyone kept the same width and just went with a larger tire? I want to go from a 285/65/R18 to a 285/75/18. Has anyone does this and what were your results?
If I went all the way up to the tallest tire I would change effective gearing from the stock 3.73 to 3.46. This would drop engine RPM from my current 2000 RPM at 70 MPH to 1855 RPM at 70 MPH. Now this might be a little low for me as I usually don't drive over 70 but if I regularly ran in the 75-80 range it might be OK. Going with 34.5" tires yields effective gearing of 3.55 and 1900 RPM at 70 MPH.
