My advice?? Pull the heads. If he won't allow you to, offer $50. If the price he's asking is ok with you, if the block turns out to be ok, then you'll pay him that price, anyway. But tell him before you pull the heads, that if it's NOT any good, then you'll walk away, because at least he'll know what he has, and he won't be ripping anybody off.
does that make sense? It's VERY rare that a block sitting out, even if out of the weather, is any good. Even a good block, not started in the last 15 years, very possibly isn't any good today. Depending on coolant, and where it is, the coolant CAN break down, turning mostly to water, voila, cracked block, if you are in sub-zero weather at all...
Or if it's stuck, can be a very bad sign - can't find it here at work but saw some pics a while back, all the cylinders looked great except 2, which were just packed with rust blooms!
I guess I'm trying to say, the flathead blocks are either very good, or very bad...there's no "so-so" blocks. They's cracked or good. Stuck CAN be overcome, but it ain't easy. so, the ONLY way to be certain is PULL THE HEADS. Personally, if they wouldn't let me pull the heads, I'd walk. Or, it might be worth a picture of Grant to find out, after it's home...or, I might give him the $50, THEN pull the heads, if cracked, then tell him it's all his, strip everything I could off the engine that's usable, to sell to get my $50 back, and let him keep it (of course, maybe it's worth the $50 in scrap??). Or, just tell him it's junk, and see if he's honest enough to give you the $50 back...
Just my opinions, and how I'd handle things...
R
