Door chime - Ford Truck Enthusiasts Forums
Texas Chapter Join Chapter, Leader: LibTimothy
Door chime
Old 01-08-2008, 11:03 AM
Shellbackcv60 Shellbackcv60 is offline
Shellbackcv60 is starting off with a positive reputation.
Door chime
Guys,
I have a 2005 F250. My door chime stays on when I open the door with out the key in the ignition. No lights on. I went to the dealer and they said they could troubleshoot for a minimum of 95 dollars. I figured I would ask you first. The one thing that might cause it to ring is there is an aftermarket dvd player hardwired to the fuse box. Other than that I have no clue. Reply when able.
Old 01-09-2008, 08:12 AM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
You might try asking up in the superduty or 6.0 forum. I haven't played with a door dinger on the newer trucks yet. Have you tried disconnecting the dvd player either where it's wired in or by pulling it out and unplugging it to see if that is the problem?
If you think it's the key in ignition chime, have you tried wiggling the ignition switch? There is a way to disable the key in ignition beep, but if you do this make sure you have a spare key.
Old 01-09-2008, 12:42 PM
Bronc45431 Bronc45431 is offline
Bronc45431 is starting off with a positive reputation.
Key chime repair
I have heard complaints about the key chime activating when the key was removed. I encountered the same issue with my 2005 F 250 Super Duty. I tried to research the problem and found many opinions but no real answer to the problem. I did the only thing left to do and that was to dig into it myself. I found the problem and the answer. First remove the screws on the bottom plastic cover on the steering wheel. When you remove the cover the lock cylinder housing is exposed. Turn the key on position forward (ignition on) The press the button on the bottom on of the ignition housing at the base of the cylinder lock with a small drill bit. This will allow you to pull and remove the ignition cylinder. Rotate the ignition cylinder until you see a brass strip with a small contacts on it. Remove and reinstall the key if the contact opens when key is removed the ignition cylinder is good. If not the lock cylinder is likely bad. If cylinder is good look at the lock cylinder housing on the steering wheel. At the 7 o clock position you should see a notch with a piece of plastic inserted into that notch. This piece of plastic is shaped like a half moon and has a thin brass strip that faces to the interior of the lock housing. This strip come in contact with the brass strip on the lock cylinder. The plastic piece is connected to a pink wire with a black stripe. . What happens is the plastic piece will fall out of the notch and the brass strip on it will come in contact with the metal lock/steering housing and ground out making the key chime activates. I found that re install the plastic piece in the notch with a small dab of epoxy seem to fix the problem
Old 01-09-2008, 12:55 PM
F350-6's Avatar
That's good information Bronc45431. When most of us go in there it's with the intent of disabling the chime. I never thought to look for any parts that might become disabled.
Old 01-09-2008, 01:22 PM
Bronc,
Appreciate the thorough email. I will give it a try this weekend when I'm putzing around the garage.
Old 03-20-2008, 10:06 PM
jvaski jvaski is offline
jvaski is starting off with a positive reputation.
BRONC - thanks for the tip on fixing the door chime !
I tried your suggestions today and it worked out fine - on my 98 F150 4x4.
The plastic piece with the contact was hanging out of the notch just as you said .
But instead of using epoxy to re-mount it - I used a plastic tie-wrap around the outside of it and the lock barrel to hold it in place permanently.
It seems to work fine now ! ( No more door chime with key out )
Old 03-30-2008, 12:18 AM
wbnethery3 wbnethery3 is offline
wbnethery3 is starting off with a positive reputation.
Psycho door chime
My 2003 SCrew does this. I appreciate the suggestions on fixing it myself. Has Ford taken any sort of stand on this being a widespread defect? I would think it should have shown up in a TSB by now. I've seen postings on other sites citing problems all the way back to the '97 model year.
Old 09-21-2008, 01:19 PM
eddierat eddierat is offline
eddierat is starting off with a positive reputation.
thanks,
took 5 minutes. the inner contact was out of the slot like you said.
it snapped back in place and the chime went away!!!!
Old 10-05-2008, 11:17 PM
I followed the directions and it worked fine. The piece I epoxyed was black cresent moon shape. When I took the ignition switch out came a little black piece.
Also had to drain the water collector on the F250. I had the light come on after filling up at Walmart.
Old 10-13-2008, 04:33 PM
jdon88 jdon88 is offline
jdon88 is starting off with a positive reputation.
Excellent post! I just bought an '05 F250 and didn't seem normal that the door chime kept going with the key out of the ignition. I followed the info above and found the plastic piece broken off. Epoxied it back together and all is good. I didn't just want to disconnect the chime because I have a bad habit of leaving the key in the ignition then locking myself out.
Old 02-21-2009, 04:41 PM
Sefner Sefner is offline
Sefner is starting off with a positive reputation.
I just wanted to thank you for taking the time to share your knowledge about the little things that drive us all crazy. I've got a 97 F150 with a door chime that was making my hair gray and my nerves shot. Thanks to you the problem is fixed. Thanks again Bob
Old 09-18-2013, 04:48 PM
axmrdr axmrdr is offline
axmrdr is starting off with a positive reputation.
Thank you for your knowledge. I ended up just pulling the black w/pink stripe wire from the plug at the base of the column. (Mine is a 02 F350) It wasn't alarming incorectly, I just grew tired of the chime as I leave my keys in the ignition with doors open quite a bit.
Old 12-22-2014, 10:28 PM
Tripodme Tripodme is offline
Tripodme is starting off with a positive reputation.
Same door/Key ignition chime situation
Quote:
Did some investigation on my 2006 F250 and found the tab was bent. No plastic tab to re-attach, tried to bend the tab back in place, it broke off. Anyone know where i can get a replacement? Tried Ford sites and Ebay but dont know what to call the dang thing ! The exploded diagrams dont show this contact under the ignition switch...
Old 01-03-2015, 02:37 PM
briatol briatol is offline
briatol is starting off with a positive reputation.
Bronc45431 you hit it right on the nose. Thank you for the great explanation, my plastic piece came loose. I found super glue to be my fix. I love it when a wire or a loose bolt will fix the problem. Now I think my door switch is defective, the chime cares not if the door is open or not. Just another curve ball no worries. Once again thank you for the correct information. Al
Old 06-14-2015, 08:19 PM
NorEasterMA's Avatar
NorEasterMA NorEasterMA is offline
Senior Snow Lover
NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.NorEasterMA has a very good reputation on FTE.
Bronc45431, I had the same issue begin occurring today and with a quick google search found this thread and your write up. About five minutes later (plus some epoxy and a zip-tie) and the problem is solved! Thanks, like Briatol said above me, love when it's an easy fix, especially with something seemingly random. Gotta love the internet and FTE! Thanks!
Door Chime bennya1 1999 to 2016 Super Duty 11 06-09-2016 10:05 AM
No headlight chime-2015 pappabake 1999 to 2016 Super Duty 4 03-10-2016 07:29 PM
Annoying key chime Neil Sandall 6.0L Power Stroke Diesel 5 02-12-2016 08:40 PM
chime whenever driver's door is open Pat S. 1999 to 2016 Super Duty 2 10-09-2015 01:52 PM
Possible to Disable Door Ajar Chime But Not Headlights on Chime moymurfs 1999 to 2016 Super Duty 5 04-28-2015 08:22 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2002, 2004, 2005, chime, dinger, disconnect, door, duty, f150, f250, ford, fuse, ignition, key, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
