Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-08-2008, 08:41 AM
dreadinger is starting off with a positive reputation.
exhaust Noise
I seem to have an exhaust noise in my 1988 F150 5.0. It is only there when the engine is not under load, when you give it the throttle it goes away. It appears to be coming from a valve at the rear of the engine. Has anyone experienced this before, it looks like it would be tuff to replace?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-08-2008, 09:42 AM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
What kind of noise? Is it a ticking noise? If you have a busted exhaust manifold gasket or loose bolts it can cause a leak, thus ticking sound.
  #3 (permalink)
Old 01-08-2008, 09:53 AM
It is more of air/rattling noise. From inside the cab it sounds like an exhaust noise but it goes away with heavy acceleration
  #4 (permalink)
Old 01-09-2008, 08:06 AM
flowriteexhaust is starting off with a positive reputation.
There is an emission tube back there, you need to see if it's just the valve thats bad or the whole tube. The tube goes from the back of one head to the back of the other and it's not that bad to get off, only 1 bolt on each side, I think it's either 7/16 or 1/2 inch wrench. The bad part is you probably have to lay down on top of the engine to reach back there.
  #5 (permalink)
Old 01-09-2008, 08:26 AM
Thanks, I looked last night and from I could see, you are exactly right. Because it comes and goes I assume it will be the valve but of course it did not do it last night. I will have to check it out this weekend when I have more light.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
