D3VE Heads
Thanks for the replies. I kinda figured the D2's were junk but the guy was in a giving mood so I took them. I didn't think the D3's were real valuable either but if I could get like $50 bucks a head that would help pay for the titanium retainers my engine builder said I need. Going to the Tri State Auto expo next month and maybe I will get lucky.
Originally Posted by 1EVILCREWCAB
maybe at your location SOMEONE would want them, I throw ALL d2 and d3 heads on the scrap pile, better heads are plentiful so I don't waste my time
REally and exactly what better heads for stock easy to aquire would you be talking about? DOVE heads? guess what they don't support any more hp then D3s do. But hey thats great that you do that means guys like me that actually know something about these motors can get a good set of heads for litterly nothing and sell our junk old heads to other people for high dollar and get enough to completely build the D3 heads.
The D3's have identical port architechture as the dove heads. They also have a 96cc closed combustion chamber which is great for lowering compression to something that can run pump gas. Typically 10 to 1 is achievable with a flat top piston. The D3 ports also have sufficient port material to open them up to SCJ sizes. Intakes will flow 360 ish CFM and exhausts are capable of 220 ish CFM if done correctly. More than capable of making 600 Hp naturally aspirated. Great low budget steet heads IMHO.
Kurt
Kurt
with zero deck, unshaved heads and flat top pistons with typical 12cc valve reliefs and .030 overbore your at 9.44:1 which makes a pretty decent street engine. shave them .030 and your at 9.83:1 still darn good for premium fuel street motor and will make very good power. run them on a 521 stroker with the same pistons and your at 10.1-10.5:1 compression depending on shaved or not.
The problem with any of the 385 heads is the combustion chamber, the d2's are just inflated 400 heads, garbage, d0ve chamber isn't as bad, d3's are almost as bad as d2's, too many pinched off areas where the flame front doesn't reach, doesn't matter how much fuel you bring to the fire if you cant burn it, I personally use 370 heads, they have enough material in the chambers to be reshaped and still keep compression around 12:1 with a flattop, on a serious motor I use 430 lincoln heads, machine a figure 8 comdustion chamber into the top of the piston for a nice 18:1 squeeze ratio, sheetmetal intake, enderle injection, on my boss 9 I spent over 600 hours welding and reshaping the chambers, made a 600+ hp difference with less boost, too bad the crank split the mains in half
Why do you always have to assume people are looking for all-out race motors? And there you go again, referring to 400 heads as junk, when there are many people making respectable power from them on the street.
Take a look at the guy's question at the start of this thread, then ask yourself why you had to do a slam fest on the different heads out there. You must have a lot of free time on your hands... You must have if you spend 600 hours working on the combustion chambers of one pair of heads.
Why can't you cool your jets before posting on this site? You are offending a whole lot of people when you post. No one will take you serious about any advice when all everyone has on here is 'junk'.
Yeah, trinogt has a Point there. Sure racing engines are not bad one bit but when you mention heads that are "junk" in YOUR opinion can and will be power makers in the rest of the world. Also MEL series parts are expensive big time compared to the D3s and the others. I dont have the money to spend on MEL parts and I dont plan on touching those heads or anyother part from a MEL.
I don't assume everyone wants a race engine, for the same dollar which would you rather have: an engine that makes 175 hp and 300lbft or 550 hp /600 lbft, with running cost relatively equal, the guy's question was if d3 heads are worth anything, my reply was scrap weight, I don't run anything on the street at less than 12:1, that doesnt make it a race engine, what everyone is overlooking or is ignorant to is thermal efficency, if you want to make less power while burning more fuel thats your perogative, when I go out wheeling with my buddy with his relatively stock 460 it costs him 4x as much to run his truck, the heads is this discussion are poor, plain and simple, ya you can make power with them but there are easier and more efficent (cheaper in the long run) ways of doing it, do you think i'm not offended to hear there are people running this stuff when there are better ways? power and efficency go hand in hand, if you improve the way an engine burns fuel you can make more power with less fuel,
I am not going to run the heads. I have run DOVE heads for years and stepped up to KAASE P51's. I just got the heads from a generous friend and wondered if I could get some money out of them to recoup the $3000 dropped on the kaase heads. I had heard that people ported the D3's were making respectable numbers for a nice street cruiser and thought that a couple virgin sets might interest someone.
