Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-07-2008, 10:45 PM
littlehellion is starting off with a positive reputation.
a few questions about my 90 Bronco ll
The tires on my truck seem to tilt inward, would any one know what could be causing this. Also when accelerating the wheel seems to go out of control and the truck is all over the road. It has a 4 inch lift. I'm not sure if this could be caused by the tire tilting in or the truck being raised.
Any advise?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-08-2008, 12:45 AM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
Needs higher degree camber bushings.
Could be because of bump steer, it might need a dropped pitman arm.
Could be simply bad shocks and you need extended length ones and/or the old ones are shot or were not long enough. The bounce test will not work well enough to determine a bad shock, you have to take it off.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #3 (permalink)
Old 01-08-2008, 06:55 PM
projectnitemare is starting off with a positive reputation.
You need an alignment. The two main causes of the problem you describe are camber issues or a toe in condidtion. Did you install a complete kit or a home made kit? Give us a little more info so we can help you. If you haven't had it aligned since the lift was put on that's your problem. Good chance you will need different camber bushings, order superlift adjustable bushings. As long as you have at least 100 miles or so on the lift after installation you can take it to the shop, that will have given everything time to settle in.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
  #4 (permalink)
Old 01-08-2008, 11:44 PM
I installed a complete kit and no i haven't had it alligened since i put the life on. I drove it to my shop tonight and when driving strait the wheel was turn about 1/4 of the way to the left. Should i do the allignment with the new 33 inch tires on it or do it with the orginial ones first?
  #5 (permalink)
Old 01-13-2008, 04:33 PM
80351's Avatar
MD Chapter LDR
80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.80351 has a great reputation on FTE.
If by original you mean the original smaller size tires than I would definately do it with the 33's just because of the size difference.
If your worried the 33's are not going to wear properly it won't hurt them but don't wait forever to align it.
Make sure that where tou are taking it to is familliar with lifted trucks.
Dave
__________________
Dave MD Chapter Leader
Mid Atlantic
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
Jeepers Cheat, Ford people are true Blue
  #6 (permalink)
Old 01-14-2008, 07:20 PM
Thanks for the advise guys... when i take some pictures i will post them on here.
  #7 (permalink)
Old 01-14-2008, 08:15 PM
The tire will have no effect on the alignment, use whichever. The alignment will be set off the wheels. As long as you don't have a bent wheel the alignment will be fine. The shop will be able to detect if the wheel is bent or not.
Matt
__________________
  #8 (permalink)
Old 01-16-2008, 11:12 AM
f100guy is starting off with a positive reputation.
http://img98.imageshack.us/img98/2725/picture027mt6.jpg
i am looking at trading my 85 f250 diesel for this truck in the pic. it too has the same problem. where and how much can i get the parts to fix it.
__________________
83 f350 dually, c6, 6.9 now for parts. pm with requests.
2001 kawasaki ninja ex500r
89 mustang 5spd. coupe, highly modded about to be turbo'd.
00 GT vert auto, exhaust and intake upgrades, nitrous
  #9 (permalink)
Old 01-16-2008, 06:09 PM
80351's Avatar
MD Chapter LDR
I just have one question, Why?
__________________
Mid Atlantic
89 Bronco 90 BII
03 Liberty
  #10 (permalink)
Old 01-17-2008, 01:28 AM
plenty of reason, although i am not sure. better fuel mileage,4x4 smaller truck.
__________________
  #11 (permalink)
Old 01-17-2008, 03:58 PM
Do the alignment with the tires on it. With a 4" lift you might have bump steer too. But, the first thing to do is get the caster/camber/toe-in correct. You can buy simple tools from JCW and do a pretty good job all by yourself.
__________________
  #12 (permalink)
Old 01-17-2008, 07:24 PM
well the guy probably won't do it because of his parents which is no big deal since i am building a turbo kit on my truck.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
