Energy sway bar end links of leaf spring trucks
Looky what I found out. I purchased a set of energy suspension sway bar bushings for my 2003 F-250. The part number is 4.5186 So I start to project to replace them and to my amazement they will not work. So I bring them back to the parts store and they tell me that they do. I say no and they say yes. I got my money back and did a google search and found this. It states that you cannot rebuild the old style sway bar end link. You have to buy new. Scroll down to F-250 and see what it says.
http://www.suspension.com/fordtruck4wd.html
Whoa neelly. I must be confused on what you are talking about. I just replaced my front sway bar bushings this weekend (rears are on back order). Are you saying that you can't get the right size or that you cant get them at all? Go to energy suspension or Summit racing and you can get them or I'm totally confused about what you are saying.
Joe
Joe
I took this of their website
F-250 SUPERDUTY 4 WD
How do we define the word 'SET'.
A 'SET' has enough bushings to do the left and right sides of vehicle.
Control arm bushing sets will also include lower & upper positions, if required.
Order one set per vehicle
YEAR
FRONT LEAF SPRING BUSHING SET
FRONT TRACK ARM BUSHINGS SET
BODY(CAB) MOUNT SET
REAR LEAF SPRING BUSHING SET
COMPLETE FRONT SWAY BAR
BUSHING SET
with coil spring suspension only.
The sway bar sets do not
include the metal brackets.
FRONT COIL LIFT ISOLATOR SET COMPLETE REAR SWAY BAR BUSHING SET-
includes sway bar endlinks
1999-04
4.2148
$58.00
4.7128
$23.00
N/A
4.2147
$63.00
4.5186
1.250"(32mm) sway bar
$41.00
This set will only fit trucks with
front coil spring suspension.
This set has two frame bushings that are
2.5" tall. 1-750" long x 1.50"wide.
This set has
4) #2592 endlink grommets,
4) #2593 endlink grommets,
that have a 1.650" O.D.(41.91 mm)
4) sleeves(15.10.245.39)
4) Flat washers(15.03.??.39),
to fit the
Endlink grommets & inners sleeves - only
to repair the endlink only.
$26.00
Sway bar frame bushing set only
is not available seperately.
4.5192
1.250"(32 mm) sway bar
$41.00
This set has
8) 4902 endlink grommets,
that have a 1.145" O.D.(29.08 mm)
with 4) sleeves(15.10.31.39)
4) bolts(15.05.??.39),
to fit the
$12.00
The Energy Suspension sway bar endlink grommets will not fit Ford OEM endlinks with these OEM part numbers:
1C3Z-5K483-BA for right side
1C3Z-5K483-BB for left side
used on the FRONT sway bars of these vehicles:
2000-2005 Excursion 4WD
2000-2004 F-350 4 WD, w/ leaf springs.
1999-04 F-250 & Super Duty w/ leaf springs.
2000-06 2 WD monobeam axle.
We do not have any bushings that can repair this style endlink.
2004-06
4-6110
4.5187
30 mm
$35.00
1999-04
HYPER-FLEX SYSTEM Complete Master Bushing Set
Includes: front track rod bushing set, front & rear leaf spring bushings,
front & rear sway bar bushings(for coil spring suspension trucks only)
The sway bar sets do not include the metal brackets..
4.18124
$188.00
ATTENTION. PLEASE READ IF YOU WANT FRONT SWAY BAR BUSHINGS FOR YOUR
2000-04 F-250, F-350 TRUCK with front leaf springs.
Ford's latest 'Better Idea' was to make a sway bar endlink with a joint on it, much like a tie rod end. This new style endlink cannot be rebuilt like the older versions. This should have been a better part than the old rubber bushings they used on older trucks, but it wears out in about 80,000 miles and they charge you $125.00 for a pair of new endlinks. To the best of our knowledge these endlinks are only available from Ford dealers. If you do a google search with the part numbers we provided above, you can find replacements for about $43.00 each.
YEAR
BODY(CAB) MOUNT SET
BUSHING SET
1999-04
4.2148
$58.00
4.7128
$23.00
N/A
4.2147
$63.00
4.5186
$41.00
This set has
to fit the
$26.00
4.5192
$41.00
This set has
to fit the
$12.00
2004-06
4-6110
4.5187
30 mm
$35.00
1999-04
4.18124
$188.00
I'm just going to say you can get the replacements from Summit Racing. They are made by Energy Suspension (see picture and post directly above mine). I just replaced my front ones this past Saturday. The hard part is pressing the old bushings out. It took a 12 ton press to make it happen. Back together is easy.
Joe
Joe
Keep in mind the old bushings only press out one way. If you look closely you'll see what I mean. I too used a 12 ton press and it was creaking pretty good. When the first bushing let go it sounded like a gunshot, yeah I shat myself. The new bushings slid right in (I used some lube on mine).
[QUOTE=locknload223;5545553]I'm sure Energy had to say this due to all the returns because the bushings are not 'plug n play'. They do work, you just have to press out the old bushing/sleeve pieces. Ask me how I know. The new bushings are made to fit these. Look at the stepped bushing on the left. They fit perfect.
bballcrf
06-06-2014 06:03 PM
SteveM14
06-18-2013 12:51 AM
