Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-07-2008, 07:04 PM
atvchick is starting off with a positive reputation.
motor rattling
My husbands 2001 Ranger with the 4.0 SOHC has a rattling sound in the motor. Sounds like it is coming from the valve cover on the passenger's side. It has 145,000 miles on it. Any ideas what this could be?Could it be the valves,maybe not getting oil to them ?
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2008, 10:30 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
The SOHC motors are prone to timing chain problems...sounds like that might be the cause of the sound. Here are a couple of threads with more info:
http://www.ford-trucks.com/forums/31...tle-noise.html
http://www.ford-trucks.com/forums/21...sohc-help.html
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 01-15-2008, 01:44 PM
Alon@ModBargains's Avatar
FTE Sponsor
Alon@ModBargains is starting off with a positive reputation.
Ya, definitely sounds like the timing chain rattle. Mine has done it since I got the truck, but seems like its getting worse/louder. I'm at 75K and I've taken it into ford, but nobody at the dealer has ever been able to hear the noise... interesting.
  #4 (permalink)
Old 01-15-2008, 10:54 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
OHC motors always have some valvetrain noise. It is just the nature of the beast. As they age it becomes more pronounced.
__________________
Member of South Carolina Mudboggers Association
94 Ranger 2wd sittin on 33x12.50's.
93 Ranger 4wd sittin on 39's.
Proud owner of 2008 F-150 4X4!!!!!!!
Needs Boggers and Lincoln Lockers
I hate Toyotas.
  #5 (permalink)
Old 02-03-2008, 05:17 AM
spirit is starting off with a positive reputation.
Has it had the 00m12 kit done, that includes a replacement tensioner and new intake seals, its worth doing as it should stop the chain from slapping around- the increased movement on the chain can cause them to break or jump and that would wreck the engine- get it done and be safe!
  #6 (permalink)
Old 02-03-2008, 05:19 AM
FTE Sponsor
Quote:
Is that the passenger side tensioner?
__________________
Phone: 714-582-3330
AIM/E-Mail: Alon@ModBargains.com
  #7 (permalink)
Old 02-03-2008, 06:57 PM
I went to ford and they gave 2 tensioners 1 for that back passenger side and 1 for the top of the motor behind the thermostat and that is the one that came with the intake gaskets but i syill have the same rattle, WHAT GOING ON KNOW.how many tensioners does it have.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
