Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Indiana Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Indiana Chapter Join Chapter , Leader: KingBigJoe
  #1 (permalink)
Old 01-07-2008, 03:21 PM
flamedoutf250's Avatar
flamedoutf250 flamedoutf250 is offline
Garage is empty, add now
flamedoutf250 is starting off with a positive reputation.
Looking for a diesel mechanic ?
I used to be a member of this chapter , but I moved and had to re-register to this site and I have asked to re-join this chapter. Anyway I was wondering if there is or if someone knows a good diesel machanic in or around the Indy area? I have an oil leak on the top side of my 2002 7.3L psd and it`s leaking down into the valley and then running back to the back of the motor and then dripping to the ground. It`s not supper bad , yet , but i would like to get it fixed before it gets bad! I looked at it and have decided I`m not going to try to find it or fix it! So any and all help would be great!!
  #2 (permalink)
Old 01-16-2008, 05:59 PM
White Shadow White Shadow is offline
White Shadow is starting off with a positive reputation.
A few things to check- the high pressure oil pump both the mounting leaked and the hoses leaked. Also check the ICP regulator mounted to the pump-the O rings and the sensor itself sometimes leaked. There are high pressure oil plugs at the ends of the heads, the O rings had a tendency to blow out too. The ICP sensor is on the front top of the drivers side head-they would blow up and leak. Lastly, check the fuel pump that sits in the valley-if it's loose, it will leak oil at the mount.
__________________
E85 powered 2003 F150 4.2 stick
2003 Focus
1997 Escort
1966 Jeep Gladiator Pickup
  #3 (permalink)
Old 01-25-2008, 08:53 PM
Alpine6 Alpine6 is offline
Alpine6 is starting off with a positive reputation.
I would guess two items. Turbo Pedistal orings or EPBV valve... or it's actually fuel and washing all the grime out of the valley and making it appear as oil. The fuel leak stems from the fuel bowl drain valve orings leaking. This is really easy to fix.
As far as a mechanic goes, Fleece performance in North Salem Indiana is a knowledgable bunch. They do mostly upgrades though. In Danville - there's Danville Performance, aka Larry's Auto Service or something like that. I'm sure there's other ones out there.
__________________
Matt
1999.5 F350 CC
MODS: DP Tuner, BTS Trans, ITP Regulated Return, Ceramic Up Pipes, ITP Intank/HPX, aFe Stg II, 5" Cannon Exhaust, and some other stuff.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
