Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-06-2008, 11:40 PM
Toreador_Diesel's Avatar
Toreador_Diesel is gaining momentum as a positive member of FTE.
SCT should I worry?
I'm having my truck re-geared from 3.73 to 4.10 this thursaday, would I need to have SCT rewrite my tunes for the 4.10 gears?
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-07-2008, 12:00 AM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
I would think that you would have to, but then again I'm not a program writer.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #3 (permalink)
Old 01-07-2008, 03:32 PM
FTE Ken's Avatar
Administrator
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
On a Powerstroke, no. It will have no impact. You'll need to use something like a Truspeed to correct the speedometer.
__________________
-Ken
Look, I'm gonna have to ask you to go ahead, just come back another time. I got a meeting with the Bob's in a couple minutes.
See "IB Tim" for support.
2006 Roush F150 Project: Roushcharger, Troyer Tuning, 9lb pulley, E-Fans, Headers, Brandmotion GPS, BlueConnect Hands-Free Phone & iPod Direct Connect, Black Head/Tail Lights, Retrax Tonneau, more...
04 F250 King Ranch Crewcab 6L PSD project: DP-Tuner Tuning, MBRP Stainless Dual Exhaust.
00 Ranger Supercab XLT 3.0 V6: Bright Box, Mac Intake, Borla exhaust, my tuning.
RIP: 67 & 75 F100
  #4 (permalink)
Old 01-07-2008, 08:06 PM
So I can leave my truck tuned and just drive off from the shop as if nothing changed?
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
  #5 (permalink)
Old 01-07-2008, 08:16 PM
FTE Ken's Avatar
Administrator
Quote:
Yes. The tuner cannot access the code needed to change speedo database for your truck, or a better way of putting it is even if those changes are made it has no impact on the Superduties.
__________________
-Ken
RIP: 67 & 75 F100
  #6 (permalink)
Old 01-17-2008, 05:55 AM
DJR96 is starting off with a positive reputation.
Wink
The speedo gets it's signal from the ABS module (ie signal from the abs sensors in front wheels/diff) Therefore changing diff ratios will not affect your speedo at all. Only changing tyre diameters will do that.
I believe there is a speed adjustment within the Xcal, this is so the transmission shift points can be corrected if you change diffs. No harm will be done if you don't do anything, fuel milage may not be ideal though. This is independent of the tunes you run. Having said that, ideally a new tune would optimize everything again. At least I think that's how it is.
__________________
Cheers,
Dave.
RCV Supertourer 6.0 V8 TDi................ (under construction)
http://www.4wdmonthly.com.au/forum/s...ad.php?t=36370
  #7 (permalink)
Old 01-27-2008, 08:54 AM
yamahonda41's Avatar
yamahonda41 is starting off with a positive reputation.
There is a Tire Rev/mile setting in the XCal 3, however, it has no effect on speedo. I tried anywhere from 500 to 600 rev/mile and I'm still reading about 5% faster than my GPS says I am really going.
The only concern I have is that with a 100k mile Powertrain warranty 5% means you lose 5000 of those warranty miles. Not good, especially if your turbo, head gaskets, or injectors take a dump late in the game...
I even tried setting different axle ratio with my X3 and you are right. Speedo was no different.
__________________
2006 F-250 Lariat 6.0L PSD 4x4
2003 Explorer Eddie Bauer 4.6L
  #8 (permalink)
Old 01-27-2008, 01:55 PM
FTE Ken's Avatar
Administrator
You need to get a Superlift Truspeed or similar product to adjust the speedo on the Super Duties.
__________________
-Ken
RIP: 67 & 75 F100
  #9 (permalink)
Old 01-27-2008, 05:19 PM
Wink
Check out your local electronics store. The sort of store that has all those kits to build yourself. In Australia we have Jaycar electronics and Dick Smith electronics. I'm sure you would have similar stores in the US. Tandy perhaps? Any, this kit is at Jaycar:-
http://www.jaycar.com.au/productView.asp?ID=KC5435
Can save a heap if you're prepared to do it yourself. Does the same thing as the Truspeed.
Besides, your Ford dealer can adjust your speedo for up to 35" tyres.
__________________
Cheers,
Dave.
  #10 (permalink)
Old 02-05-2008, 10:59 PM
Mercury45 is starting off with a positive reputation.
the dealer can flash 34.5" tires into the abs module on these trucks.
speed wizard / truspeed / jet accuspeed are all nice options. I use speed wiz on mine and love it.
as for the one that you build.. looks nice and all, but who do you go to if there is a problem? Also, it looks like it corrects in 1% increments (I am guessing) so the best you can be is +/- 1% I know mine is <1% error from 0 - 100 based on my gps
kenny
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
