Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-06-2008, 05:49 PM
bikerbrad1967 is starting off with a positive reputation.
fuel pump problems
2001 escape 2.0 litre. my son started it yesterday drove a few feet into the driveway, shut it off to put fuel in it. After fueling it up it wouldn't start again. Checked out fuel system and there is no fuel getting to the engine. Checked all fuses and diodes and swapped fuel pump relay with known good one, checked fuel pump shut-off and it is working correctly. Seem to have lost the ground to the fuel pump relay. When I ground terminal 86 of the relay fuel pump works fine. With relay removed when I jump terminals 87 and 30 pump works fine. Does anybody know where terminal 86 gets its ground from? Am I missing a switch or sensor somewhere that has failed and grounds this terminal 86? Anyone link me to an online wiring diagram or post a diagram? Any help would be greatly appreciated!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-06-2008, 06:30 PM
antony25 is starting off with a positive reputation.
when you turn on the key does the cel illuminate? If not you may have a faulty EEC relay.
  #3 (permalink)
Old 01-07-2008, 06:27 PM
By cell I will assume u mean instrumentation/dash and idiot lights, yes it does. Just got a wiring diagram from local Ford dealer. Looks like fuel pump relay grounds through the PCM. Dealer wanted to know if the THEFT light is flashing with the key on, if it was the PCM will not turn on the fuel pump. They say that it might not recognize the ignition key, but THEFT light is not flashing. Anyone out there have a PCM failure?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
