Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #76 (permalink)
Old 07-04-2008, 12:53 AM
Az.scarecrow's Avatar
Az.scarecrow is starting off with a positive reputation.
Quote:
Originally Posted by jdecker88 View Post
It can have its fun days, we just got bought out and we are hoping to get a new plant soon. We have an old 1950s model batch plant it isn't too fun chugging along at 200TPH :-p. I would love to run our nicer drum plants that are all computer operated ours are auto/manual controls so we don't just sit back and watch it. Your running your mix a little cool out there we run ours 330-350 on everything but D mix.
At leat you had some nice loaders heh we just got a 966F for the plant and an old 980 for our RAP proccessing crusher at the other end of the facilty.
200TPH You may want to speed her up before she stalls
J/K
Depending on how wet our washed sands are, our drum mix plants would run between 280 and 400TPH. Them guys would need belly dumps, a pick-up machine and a 5" thick lift/mat to push a drum mix plant with dry materials on a Hwy job. What holds up our plants is the FOB's or should I say SOB's that all want 15 tons of a different mix.
As for temp, even with the PG oils, we target 320-325F at the slat conveyer, I would guess you keep your aggs & sands at 300+ temp with your stack plant.
I miss them days, now I work out in the road as a field engineer/inspector, and wonder when one of these bone head drivers are gonna hit me.
__________________
Why spin the tires, when you could spin the Earth!
00 F250 PS 4x4 CrewCab Shortbox XLT
Aluminum MB Motoring-285/75-16 BFG A/T's
Rhino Hardlined with UnderCover Bed Cover
Autometer 3 pod pillar, 6637 intake & 4" exhaust with muffler delete
DP Tuner from ITP Diesel - 40t+80e+140+drive-thru+high idle & JW Valve Body.
Sponsored Links
To remove this ad, register today!
  #77 (permalink)
Old 07-04-2008, 09:39 AM
ford1183's Avatar
ford1183 is starting off with a positive reputation.
I lay natural gas lines
__________________
clif
2001 FORD F-350 MODS... RAM AIR INTAKE,U.S.GEAR FAN,D.B.ENGIEN BREAK,LIFT WITH 36IN TIRES,PILLER GAUGES,BULLY DOG CHIP,CCV MOD,FOIL DELATE
  #78 (permalink)
Old 07-04-2008, 10:24 AM
mueckster's Avatar
Redneck Wrencher
mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.mueckster has a very good reputation on FTE.
My PMS money comes from my small cattle operation and doing mechanic work, "on the side", for a friend/water well driller. I've been doing work for him for the last 25 years. We rebuild drilling rigs for resale, also. My regular job is doing maintenance and repairs on a fleet of OTR tractor /trailers, dump trucks, and heavy equipment.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner, AFE II w/ Pete's Cover, ATS housing, Zoodad, SS HPX, IAH delete, 203* stat, Phantom gauges, MAP Reg, tank mods, DIY HD 4R100, 4" MBRP exh, coolant filter, shimmed FPR, Turbo Master, CCV oil trap, Procomp lift pump, CCK, TruCool, EBPV del, 140v IDM, GP LED, Foil del
PAA Member #62
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
