Block Heaters, when do you start plugging in?
New user to the site and to owning a PSD.
A couple of weeks ago when it was cold here, I started the van, after waiting for about 5 min. while loading and scraping the windows. I drove off and encountered the EBPV closing which meant no power and the air leak noise. After reading a bunch of threads I found that is normal. More reading and people suggested using a block heater to shorten the warming period.
Found the block heater cord under the hood, looks like the previous owner (original) never used it.
Reading the "Ford Owner's Guide Supplement 7.3 Liter Power Stroke Direct Injection Turbo Diesel", page 12 "Engine Block Heater" section.
It says "It is recommended for use whenever the outside temprature is 0*F [-18*C] or below."
It won't get that cold here, but will plugging it in for three hours before starting help with the warm up to stop the EBPV from closing?
The temprature I was thinking of plugging in at would be 32*F [0*C].
1997 Ford E-350 with 7.3 PSD
Quigley 4x4 conversion
Have my ebpv unhooked and this winter always connect the block heater for three hours before I go to work, on a timer. Low temps here are in 30-20-Teens. Sometimes I forget after work to connect power cord then although the truck start just fine I just don't have that throdle response and very poor heat in cab. I think everybody is different but for me I plug the beast in every night as I enjoy the cab heat within a few miles.
on
1 Post
I don't have the EPBV since I have a exhaust brake.
I plug in when it's going to be below freezing. I usually do it about 1 hour before I go and that helps a lot. It just takes the chill off the engine but doesn't really warm it up. At three hours or more, the engine is 140F with the block heater on.
i got mine on a timer too but only two hours before i leave the house but its set for like 6 hours just incase i ' m running late and i have the ebpv on a switch and the high idle my truck gets up to operating temp in just under two mins. thats no joke I timed it one day to see how long it takes it was 20*F the day I timed it
