429/460 48 Ford F1 - Page 8 - Ford Truck Enthusiasts Forums
429/460 48 Ford F1
  #106
Old 04-19-2009, 01:24 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Just to tie everything together, here's the link:
http://www.ford-trucks.com/forums/81...on-mounts.html
Ps Edit Note - no sweat, I also updated it with some new pics...Like these! I think they pretty much clear up the cross member questions - it's gotta go!:
Hope you feel better soon - drink plenty of fluids. Tequilla works, it won't cure the cold, but you really won't care!
  #107
Old 04-19-2009, 01:31 PM
StevoF1's Avatar
StevoF1 StevoF1 is offline
StevoF1 is starting off with a positive reputation.
Thanks Julie, I should have added the link. Got a cold today, head isn't too clear!
  #108
Old 04-30-2009, 09:29 PM
StevoF1's Avatar
Here's a few pictures of everything coming together. $60 bolted to C6 ready to go in, and the cutout tranny member with new member wating to go in.
  #109
Old 05-01-2009, 09:19 AM
pells49 pells49 is offline
pells49 is starting off with a positive reputation.
wow, lookin good, steve! Looks like you're almost there!
  #110
Old 05-01-2009, 10:44 AM
StevoF1's Avatar
Thanks Justin. How's your truck coming along?
  #111
Old 05-01-2009, 11:28 AM
Oh, you know...pretty slow going. I recently joined the unemployed of america, got laid off, so moneys been a little tight. Though I did come across another 48 f-1 about two months ago with what looks like a good 8ba flathead in it and a title for 500 bucks, so I may have the engine I've been looking for if it turns out to be good and not junk. I now have a title in my name, which is a huge relief! I haven't tore into the engine yet, still need to pull it out of the truck. It sure is nice to have another whole truck of parts when you're doing this kind of stuff! Let me know if you need help dropping that engine in...
Justin
  #112
Old 05-01-2009, 06:08 PM
StevoF1's Avatar
Thanks Justin. Sorry to hear about your job. If you want I have a friend who is a contractor I can give you his number if you p.m. me. Nice score on the second 48 Ford truck! Thanks for the offer.I may take you up on it.
Steve.
  #113
Old 05-02-2009, 02:12 PM
StevoF1's Avatar
Well after a trial fit today it looks like some more firewall modifications are in order. The engine touches the fire wall just about an inch to far foward. It sits low enough that just a little bit of cutting and reshaping may be needed, this will give me more room for the tranny mount farther back away from the brake booster too!I hate to do it, but I guess this is what hot rodding is all about!
  #114
Old 05-28-2009, 11:21 PM
StevoF1's Avatar
Got the engine in a couple weeks ago and just got the tranny mount back from the welder today. Had to modify it a bit to avoid the brake booster. Getting closer! Had a few problems but all is good for now!
  #115
Old 05-28-2009, 11:58 PM
Tomget's Avatar
Tomget Tomget is offline
Tomget is starting off with a positive reputation.
tranny crossmember
Looking good Steve. I'm doing some work on my tranny crossmember too. I decided I wasn't happy with the crankshaft/pinion angles I was getting - I need to raise the back of the tranny a few inches so I'm in the process of making a spacer etc? or maybe I'll just copy that nice looking thing you had built. That looks a lot better than my cobbled together stuff. Lookin good.
Tom
  #116
Old 05-29-2009, 12:37 AM
StevoF1's Avatar
Thanks Tom. I actually bought the cross member from Classic performance parts, for 49 bucks, but it didn't work with the converted brake booster though, so I took it Shoemaker's welding in Penngrove and had them modify it to fit around the booster. Still cheap even with the mods.
  #117
Old 05-29-2009, 09:38 AM
Tomget's Avatar
tranny crossmember
Thanks for the info Steve, I may go that same route. I've got a pile of scrap metal around here and sometimes I can put something together, but your's looks better.
Tom
  #118
Old 06-11-2009, 07:45 PM
StevoF1's Avatar
Here is a picture of the modified transmission crossmember in place.
  #119
Old 06-11-2009, 07:49 PM
StevoF1's Avatar
Got a bunch done to the engine today. I mounted the march performance alternator bracket, which relocated the alt. away from the bottom of the engine and the frame. I also worked on lots of little stuff, like sealing all the vacuum and water plugs in the intake, putting in the new sending units for temp and oil, putting inspection plate back on tranny, and working on replacing the u joint so I can get the drive line in. Lots of trips to Napa and Rex hardware today!
  #120
Old 06-15-2009, 09:15 AM
hot51's Avatar
hot51 hot51 is offline
hot51 is starting off with a positive reputation.
Looks good. You said you had to cut some of the fire wall to get the motor back. Can you show us how much and where you cut it. I plan on going with a 460 in my 51 f1 and any information I can get is helpful for when I do it. The only thing is my truck has a Volare front clip in it.
Engine options to replace 351m Lovingfoss 1973 - 1979 F-100 & Larger F-Series Trucks 25 09-08-2014 11:08 PM
66 brake booster w/429 bstdad2 1961 - 1966 F-100 & Larger F-Series Trucks 0 01-30-2014 12:47 AM
Good 460 cam specs? xirxious 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 06-23-2010 12:06 PM
Convince me - 429/460 vs. 351/400 bbtkd Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 06-08-2002 04:57 PM
351w-351m-429-460 which one? orangeford 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-27-2001 06:47 PM
Tags
1948, 1950, 429, 460, 48, brake, conversion, doae, doae9425f, f1, firewall, ford, kit, power, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
